Old December 26, 2009, 02:06 PM
Varroa's Avatar
Default Re-mounting 775 backplate
Hi, I am in the process of replacing my motherboard and I need to move the 775 backplate to the new motherboard. When I removed the backplate from the old board it left behind the foam/tape that was used to mount it. I can replace the foam with paper or rubber washers at each hole but I was wondering what I can use to at the center of the place, directly below the CPU. Can I use thermal pads? Double sided tape? Any suggestions would be great.
Thanks.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old December 27, 2009, 06:28 AM
Dr_BenD_over's Avatar
I used some adhesive backed cork/rubber spacing material.
If it's stupid and it works, it isn't stupid.
[WTB] Asetek LCLC/Corsair H50 775 mounting kit CMetaphor Buy/Sell & Trade 11 November 6, 2009 05:47 AM
[WTB] Backplate (local) DenisS Buy/Sell & Trade 2 September 23, 2009 08:57 AM
[FS] Swiftech Apogee GTZ CPU block 775 and 1366 Mounting kit donkon Buy/Sell & Trade 7 July 18, 2009 01:34 PM
Backplate question DenisS Air Cooling 4 April 5, 2009 09:06 PM
thermalright backplate owners Zippoh Air Cooling 3 December 15, 2008 06:05 PM
