Old December 26, 2009, 09:56 AM
To Olorin, you will see a night and day difference, although go with a x4 955BE ( save a few $)and after market hsf vendetta 2 or comparable. I went from a x2 6000 to the x4 940BE and it was a big difference.
Whiteangel, you'll see a difference in multi task but not all that exciting, depending on your budget try for a x4 955BE ddr2/ddr3, x4 940BE does ddr2 only or a x3 720BE ddr2/ddr3. If your in to gaming the a 4890 is a good budget card $180-200 max and packs a punch, 5770 packs less of a punch, if no gamiing most sale sub $100 card will do.
To both the BE version (black editions ) have unlocked multi so it's designed for easy overclocking, x4 940 and x4 955 should do 3.4ghz with ease.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.4GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old December 26, 2009, 10:52 AM
Fudd Rucker's Avatar
why spend 350 on a lesser performing setup? both an i5/board and 965/board are the same price and the i5 destroys the 965 at both stock and overclocked speeds. I just went from an AMD 955 @ 3.9ghz and it has no where near the power of my i5 @ 4ghz.
Im all about best bang for the buck and at the moment the i5/i7 + p55 is the best bang for buck you can get.
I couldnt think of something snarky or interesting to put here this time around.
Old December 26, 2009, 12:23 PM
mchutch's Avatar
Best bang for buck is different for every person, as their PC needs differ.
I know people that are happy with a P4, 512MB DDR333 and a ATI 9250 SE lol, because it does what they need.
The simple answer for this thread is being overlooked. Going from an AMD 64 to AMD Phenom? Yes it is a nice jump in CPU performance.
I still agree with everyone on the video, 8300 is like 2 gens newer then the 6600, and you will have "access" to Dx10 but it is a very meek graphics offering, the Nv 8600 or better or ATI 3850 or better would be great if you could afford it.
Old December 26, 2009, 01:29 PM
Legion Hardware
Legion Hardware
Legion Hardware Includes x2 6000
Legion Hardware
There's some reference of scaling with higher end gpu on different cpu speeds and generations.
Old December 26, 2009, 03:04 PM
Sushi Warrior's Avatar
I would go to the X3 720, the tri-cores offer the best value by far.
Old December 27, 2009, 10:15 AM
Thanks for posting the links. I guess what makes things even more interesting is that some of those benchmark results are using AMD CPU's that are a generation old. The latest current CPU's will obviously beat the previous generation. Does anyone have a 6000+ or 6400+ x2 cpu to compare with the i5 750 for gaming :))
Regards,
Old December 27, 2009, 03:58 PM
AnandTech Bench (beta): AMD Athlon X2 6000+ vs Intel Core i5 750
Don't know how reliable it is but it's a start.
Two New Cut-Offs: Core 2 Duo E7300 and Pentium Dual-Core E5200 Processors (page 6) - X-bit labs
Another site to read up on. Long and short the x2 6000 has been passed by, even the x3 720 ($133ish newegg)is a better cpu.
The i5 750 deals that are floating around make it look like a better buy for the long haul. It's a real toss up x4 955 or i5 750 depends on price I guess, if I was in the market now I'd prob go i5 750..
Will enabling AHCI boost performance? Matt Storage 17 February 20, 2010 07:22 PM
FSB boost or GHZ boost? J2TheROC Overclocking, Tweaking and Benchmarking 14 August 13, 2009 09:33 PM
WIn XP to boost Gaming? jcmaz New Builds 10 April 26, 2009 01:08 AM
Has Anyone Tried Ready Boost? norfolk RAM 5 February 9, 2009 07:08 PM
I wonder if this works with Ready Boost... Cardboard box with DSL O/S's, Drivers & General Software 5 July 1, 2007 01:11 AM
