X58 vs P55 build decision I've decided to upgrade my primary system, which currently is built on a (gasp!) A8R-MVP. I've just finished 2+ years of crazy long work hours so it's time to reward myself. :) Primary uses: software development + gaming Must be quiet. Will be overclocked. I value stability above all else. Common hardware for all builds: - modded Coolermaster C5 case - Seasonic X750 PSU - Radeon HD5870 - 1 x Vortex SSD - 3 x 640 GB WD Caviar Black - 1 x DVDRW - Auzentech Forte - Xigmatec S1283 + crossbow kit So far I've narrowed it down to: X58: Pros: mature platform, mature BIOS, 6 RAM slots, slightly better PCI-E Cons: more power/heat Gigabyte GA-X58-UD5 + i7 920 + 6GB G.Skill = 746 CDN Pros: nice layout, great bios updates, dynamic VID in latest bios! Cons: bit colorful, reports of squeeling (but it sounds like that can be solved in bios) EVGA X58 ATX A1 + i7 920 + 6GB G.Skill = 760 CDN Pros: lifetime warranty, nice design Cons: active northbridge cooling (need to mod it for quiet) P55: Pros: cheap, less power/heat (~$45/year electricity difference) Cons: new, possible socket issues? MSI P55-GD65 + i5 750 + 8 GB Kingston HyperX = 578 CDN MSI P55-GD65 + i7 860 + 8 GB Kingston HyperX = 688 CDN Pros: cheap, nice layout, can turn annoying LEDs off Cons: questionable support and quality control EVGA P55 FTW + i5 750 + 8 GB Kingston HyperX = 638 CDN EVGA P55 FTW + i7 860 + 8 GB Kingston HyperX = 748 CDN Pros: cheap, nice layout, useless 'e' LED power can be unplugged Cons: no IDE, useless 'e' LED reported to squeel for some, 2 year warranty, almost same cost as X58 Any thoughts/opinions welcome. :) |
Oops, meant to post this under New Builds, but I can't move or delete the thread. |
I would say EVGA X58 build, as 1156 is a dead end of sorts. If you ever want to upgrade, make sure you have 1366 (new hex-core anyone?). X58 also has much better multi-GPU support (with 16x/16x). If I were to go 1156, I would also consider an EVGA board due to their solid designs and amazing support. I would call them the best support out there. |
eVGA X58 build imo. I actually took off the northbridge fan and just left it running passively. The 120mm fan on my U-120 pulls a bit of air across the massive heatsink and it's enough for it. |
Thanks guys I appreciate that. I wonder if EVGA is planning to add dynamic VCore to their BIOS? That's a pretty cool feature Gigabyte just added to the UD5 -- it adjusts the core voltage with load, so you can have say 0.976 volts at idle and then bump up to 1.232 under load. |
Probably not. People buy eVGA boards to overclock the shit out of them. Power Efficiency be damned! |
Thanks for your help, guys! I ended up going with the Gigabyte UD5 since it was on sale at NCIX for $299. Also grabbed 12 GB of the G.Skill instead of 6 since it was on sale. Only other change was an OCZ Agility instead of the Vertex since I missed the sale price on the Vertex, and the Agility was on sale fore $199 vs. $256 for the Vertex with a price match. Now to wait for the boxing day shipping queue. :) |
id go with x58, leaves you a route to upgrade to the upcoming 32nm 6cores |
Did your parts arrive? Do you plan on overclocking ? Every thought of water for lower noise ? |
| All times are GMT -7. The time now is 08:19 PM. |
