Old December 21, 2009, 07:55 AM
r0k0's Avatar
Default Motherboard Question
Hey Boys, i've got a question..
i've got a deal on a Gigabyte GA-P35-GS4, is this board any good also,
i've looked into the specs and says only qualified vendors ram is valide for this board, my ram aint in the list.. and the ones i was gonna purshase also aint in there...
if its not in the list the mobo with not run them..?
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old December 21, 2009, 08:55 AM
martin_metal_88's Avatar
The mobo will run them with no problem. They never test all mobo with all memory on the planet. What is the deal for this board??? I wont paid more then 80 for it according that it's maybe more then 2 years old and it's a dead unit (they don't produce it anymore ) What is you system spec for the moment also???
Old December 21, 2009, 01:29 PM
r0k0's Avatar
system specs are all in the sidebar ;)
i guess i'll remove that from there and put it back in my sig.. :P
Old December 21, 2009, 02:00 PM
I don't see any reason to replace your current board with an old P35 board. If you really want to swap it for something better, get something like the ASUS P5Q Pro Turbo/P5Q-E or Gigabyte GA-EP45-UD3P/GA-EP45-UD3R instead.
Old December 21, 2009, 03:21 PM
r0k0's Avatar
tought the gigabyte was better...
cause i cant overclock at all this cpu in this board
Old December 21, 2009, 03:42 PM
The Gigabyte is better, but not enough to warrant upgrading to such an old board when there are much newer and much better P45 boards out there like the ones I suggested to you.
Old December 21, 2009, 04:03 PM
r0k0's Avatar
would a eVGA 750i SLi FTW mobo be better..?
Tigerdirect has some in stock at around 150$
i'd get this : Buy the EVGA nForce 790i SLI Digital PWM - Recert at TigerDirect.ca
But it needs DDR3 memory... and i only got 4GB of DDR2
Old December 21, 2009, 04:05 PM
No, all of the boards I suggested to you above are better. Here are some links:
Newegg.ca - ASUS P5Q Pro Turbo LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards
Newegg.ca - GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards
Newegg.ca - GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards
Old December 21, 2009, 04:10 PM
r0k0's Avatar
but i want a nVidia Board.. so later i can buy a second GTX 260.. :P
Old December 21, 2009, 04:14 PM
Well you should have mentioned that earlier. The Gigabyte you were looking at doesn't fit that requirement anyway. If you were to get an nVidia board, the EVGA 750i SLI FTW is the only one I would suggest. However, you'd be better off with a P45 board unless you really want to go SLI in the future.
Motherboard I/O Panel Question miggs78 CPU's and Motherboards 10 September 25, 2009 03:31 PM
Motherboard Question r0bc CPU's and Motherboards 11 August 8, 2009 03:48 PM
Motherboard Question r0bc CPU's and Motherboards 2 June 1, 2009 05:28 AM
Motherboard and thermal paste question CORE CPU's and Motherboards 8 May 23, 2009 03:12 PM
New motherboard Infiniti CPU's and Motherboards 6 April 30, 2008 06:55 PM
