Old December 20, 2009, 08:21 PM
kendallcschm's Avatar
Default Fact or fiction?
Rumor has it that the newer AMD AM3 CPUS are AM2+ compatible.. is this true?? if so then i got a new CPU plan coming up :-P so is it true or is this just fiction? i find it hard to believe that a CPU with 2 more pins can fit in a socket with Less pins
Old December 20, 2009, 08:29 PM
MarkOne's Avatar
srumours ? it's a fact the socket am2+ have 940 hole the am3 cpu 938 pins.
Old December 20, 2009, 11:26 PM
FlyingFish's Avatar
Apparently they do work since the AM3 CPU can use DDR2 or DDR3 RAM.
Socket AM2+ - Wikipedia, the free encyclopedia
Old December 21, 2009, 12:21 AM
All AM3 CPUs are backwards-compatible since they have DDR2 memory controllers. However, AM2/AM2+ CPUs cannot be used in AM3 motherboards.
Old December 21, 2009, 03:51 PM
Bond007's Avatar
Exactly. I have an AM3 CPU in DDR2 equipped MOB (see sig)
Old December 21, 2009, 06:42 PM
sweet.... these are the responses i was hoping for
Old December 21, 2009, 07:05 PM
sswilson's Avatar
The only Caveat would be to do the research on your AM2 motherboard..... Some of the original AM2 boards couldn't handle high power AM2 chips let alone AM3 chips.
Old December 21, 2009, 07:19 PM
my board can handle 140 watt CPUs and it can handle AM2+ CPUs
Old December 21, 2009, 08:11 PM
Bond007's Avatar
Check your MOB website for support list. If it is AM2+ and 140W rated I can almost guarantee you that you are good to go ahead with a new (AM3) CPU. Like I said before, I just bought my AM3 x3 710 in June with an AM2+ MOB and worked perfect out of the box. Only thing is you will likely have to do a bios update so that it recognizes the new processor.
Old December 21, 2009, 10:35 PM
martin_metal_88's Avatar
This as never been a rumor? it's like that from the bigining and it was the principal sale argument when they came out. Just get a new CPU, get the rest later;)
Your Favorite fiction novels muse108dc Off Topic 22 March 23, 2009 06:48 AM
