Old September 23, 2007, 03:01 PM
Default Dfi P965-S Dark and Q6600 Overclocking
If anyone has a Q6600 along with this board please post your overclock results and the settings that you used...
I just got my 'GO' and anything above stock just doesnt work.
I have newest bios and Coolermaster GeminII with 2 x 120mm 125CFM Fans, so cooling is not a problem, I have tried everything from Stock volts to 1.5V no luck.
Old September 23, 2007, 03:14 PM
sswilson's Avatar
Did you do a full bios reset?
I found the "Dark" board didn't particularly like having the cheeze moved, so it probably will need to start from scratch.
Haven't picked up a quad yet, so I can't help you with regards to settings, but you might want to have a look here Intel Chipset-Intel CPU - DFI Club Global Support Forum .
Just a heads up though if you aren't already familiar with the rules over at DFI-Club.... they're pretty anal about things like sigs and including your geographical location in your user profile.
Let us know how you make out.... never know, there might be a quad core in my near future and I'd be able to use whatever you find out. :)
Old September 23, 2007, 03:16 PM
sswilson's Avatar
Just a quick suggestion..... seems to me that the GTL+ Driving strength was a critical setting specifically for quads. Might want to muck around a bit with it. (only three settings so it shouldn't be a duanting task.... :) ).
Comment thread for DFI Infinity P965-S Dark review sswilson CPU's and Motherboards 34 August 23, 2008 05:49 PM
Please post your DFI P965-S Dark Timings keenan CPU's and Motherboards 8 August 1, 2007 11:20 AM
DFI Infinity P965-S Dark keenan CPU's and Motherboards 10 July 26, 2007 11:30 AM
DFI P965 Infinity Dark review by PCTuner Babrbarossa Reviews & Articles from the Web 1 May 21, 2007 07:53 AM
