what do you guys think the odd's are of unlocking a 550? Is amd doing anything with newer built 550's to disable this?
juggling between a rana aII x3 435 or the 550 x2be which is a little more expensive. With many newer games getting use out of multple cores(gta4, x3 tested better then 550BE
http://www.tomshardware.com/charts/2....0.3,1402.html i'm wondering if i should go with the cheaper 3 cores and just over clock them a bit?(just for 720 gaming)
is a l3 cache really important for games?
is the Black edition gonna be easier to overclock? this will be my first
what do you guys think, save the 15 bucks and go athlon 3 which can aslo unlock fourth core , orrr... do i go phenom BE with that hightech name and hope for 4 cores of badness??
for 720 gaming
getting Asus M4A78T-E with sb750
opinion's? kind of leaning toward's the BE but i could put more money toward a gpu if i go with the rana (getting Asus M4A78T-E with sb750 if i)
