Old September 21, 2007, 10:51 AM
xrmarcis's Avatar
Default Opteron Experiment
Whats up everyone. I'm new to this forum and though maybe some people might be interested in my little experiment.
Newly purchased.
Opteron 180 (Toledo) 2.4Ghz 2Mb cache
Asus A8N32 SLI-DELUXE
EverCool Silver Knight WaterCooled Heatsink
Other System Parts
XFX 7900GS XXX 256Mb PCI-e (Plans for SLI soon)
2 x 1Gb OCZ PC3200 ELPE (2.5 - 3 - 2 - 5)
2 x 250Gb Hitachi SATA II IDE Mode
LITE-ON DVDRW LH-20A1L SATA
My goal is to at least Hit 3.0Ghz which is really not that much of an overclock but thats my starting goal.
Anyone have any experience with the opterons and or this asus board? Any input would be appreciated
Another question that i thought i should ask opinions on would be investing in another card for sli or a better card? I'm sure there are plenty of people out there including myself that going to a newer age card would be the way to go but would SLI with these cards stomp a single newer card?
Well post if you got any info.
Old September 21, 2007, 12:04 PM
arbb5's Avatar
Welcome to the forum from a fellow Truro man, I am running a Opty 165 24/7 Stable at 2.7Ghz with a A8N-SLI SE. Opty's are usually good overclockers depending on the steppings.
A couple free programs you might want to use are a64 MemFreq, and ClockGen. ClockGen lets you change the FSB(HTT) in windows and MemFreq calculates RAM speed. When you get it running good in Windows restart and change setting you got in Windows into Bios. This page helped immensely: AMD64 Overclocking Guide (07/11/06) - i4memory.com Good luck with it.
Also what temps are you getting with that cooler?, I am getting approx 45-50 under load with the vcore @1.45 IHS removed from the cpu and the freezer64.
Phenom II X2 555BE Unlocked to X4@3.6ghz / GA-870A-UD3 / 4 Gig (2x2GB) G.Skill F3 Ripjaws / EVGA GTX260 / Skythe Yasya / Tagan 2 Force II 600W
Old September 21, 2007, 02:45 PM
magictorch's Avatar
Default greetings
Ah so the 939 isnt dead yet! Personally I think youve made a good choice as long as the price was good.
I really like the opterons, games are very smooth-the extra cache helps. That board is also very solid and fast.
There is a guide to ocing the asusa8n32 board in the forum..its really important to get the HTT settings right. A8N32 Quickie OC guide
With the multi on your cpu and the headroom on your board 3ghz is not an issue.
It really depends on your cpu stepping though. CCBWE i think was the not so good ..CCBBE, LCB9E are good ones. Just follow arbb5's link and keep the temps below 55oc otherwise its not good.
My only irritation with this board is that you are forced to link memory to the FSB with preset frequencies only. This should not be an issue with your multi on the cpu though.
I can hit an 2.95 on this opteron comfortably but have to drop the RAM from 166mhz to 133mhz as it cannot handle
DDR270*2. This then drops the RAM to DDR218*2
have fun anyway
Old September 21, 2007, 04:41 PM
sswilson's Avatar
Looking forward to hearing how you make out with this build.
I have fond memories of my S754 & S939 overclocking experiences.
There are quite a few good resources out there for overclocking S939, so you should have no problems finding a good guide.
Once you get the CPU OC stable, do some googling for the A64 memory overclocking guide. CPU speed trumps mem on S939, but there are some major gains to be made from spending some time on your mem timings.
I didn't quite manage a full 1 sec improvement of 1M super-pi, but it was at least .75 of a second.
Oh... BTW... welcome to the forums!!!!
It's great to see another down-easter here on the forums!
Old September 21, 2007, 05:25 PM
Amon's Avatar
The Opteron 1xx family were one-way workstation chips for 939; very, very popular with overclockers in the past as well as recently as their trading prices have gone down. You'll be able to pull 2800MHz quite comfortably, no concerns aside from the factory heatsink's thermal pad. The most you'd need is a more conductive thermal compound to replace the original and you're set. Optys are really just higher-yield versions of the Athlons from the same wafer, with better heat and frequency tolerances. 3000Mhz is going to need a replacement heatsink. Maybe put the computer near the air-conditioner for an improvised boost in cooling?
Nice memory.
P.S.: If memory serves me right, the dual-core 1xx family were based on the Denmark core.
Old September 22, 2007, 10:00 AM
xrmarcis's Avatar
Thanks for the feedback and i will try to do overclocks today.
For temp software what should i be running???
I tried MM5 but it does not seem to pic up my sensors even though there not going to accurate it would be nice to get some idea of what its running at. Its funny it lists A8N32 SLI wireless version and not my board the SLI deluxe???
Should they not be close to the same architecture?
I had thought about running a dry hose from my mini bar fridge to the front of my case to get it some cold air but i'll see how the heatsink works first. lol
My buddy just bought my Opti 165, AC cooler and DFI Ultra-D board that i had running before and he puished it to 2.25 so far. He loves it so thats what gave me the idea to get a decent cooler and see if i can push my new opti just a little.
Any comments on the video portion of my first post????
Intel E8400
4Gb OCZ DDR2 1066
XFX 8800GS XXX 384Mb
750Gb WD Black SATAII
LITE-ON DVDRW SATA
Windows 7 64 bit
Old September 22, 2007, 10:35 AM
magictorch's Avatar
Default dont go sli
with your board and that cpu >2.7 th enew 8800 series run very very well. You should be able to nudge 9500 3dmark06 with a superclocked GTS. A GTX will break the 10000 barrier with that cpu no problems. In SLI with the 7900GS i doubt you break 7000 no matter how much you oc it.
Old September 22, 2007, 04:07 PM
arbb5's Avatar
I find that Core temp work about the best for me, you can get it here wwe.thecoolest.zerobrains.com/CoreTemp/
Old September 24, 2007, 12:44 PM
Cptn Vortex's Avatar
I have an Opti 170 on a DFI Nforce4 SLI Expert, and it runs 2.95 Stable as a rock, at 55 degrees Max. Lovely chips!
would a 8800GTS be bottleneck by an opteron 165@2.4ghz magictorch CPU's and Motherboards 16 June 19, 2007 07:57 PM
AMD readies 50% Opteron price cuts Babrbarossa Press Releases & Tech News 6 May 31, 2007 05:31 AM
good 939 motherboard and case for opteron 165 magictorch CPU's and Motherboards 7 April 9, 2007 02:44 PM
opteron 165 will not POST magictorch Troubleshooting 13 April 9, 2007 02:34 PM
AMD rolls out 3GHz Opteron Babrbarossa Press Releases & Tech News 1 April 9, 2007 06:11 AM
