Old December 8, 2009, 04:11 AM
Default 550 BE unlocked
I managed to unlock my other 2 cores
now running 4 cores@3.1ghz stock voltage .10hrs prime stable...my goal is 3.8ghz but will push for 4ghz.
is there any prog that can display temps of unlocked CPU? or do i just go by previous oc's/temps..
EG: Would 4 cores@3.8ghz 1.360v give same temps as 2 cores@3.8ghz 1.360v?
or would cpu be running hotter because of extra 2 cores working?
Edit: also is it normal to need to do fresh install after each bios flash? getting sick of installing windows
Thanks
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old December 8, 2009, 07:00 AM
4 cores should be hotter than 2 since they're supposed to be disabled in the stock 550 BE.
Intel Core i7 920 4.1GHz w/ Thermalright U-120E
24GB G.Skill 1.25v DDR3-1600 9-9-9-24
eVGA 758 - A1
80GB Intel X25-M G2
1TB WD Black
1.5TB Seagate 7200.11 (still works!)
10.9TB RAID6 Samsung F4EG
XFX 5850 @ 1000/1250 w/ Scythe Setsugen
2X Dell U2412M Seasonic M12 850W
Old December 8, 2009, 07:26 AM
Shouldn't need to reinstall Windows each time - I certainly didn't when I flashed the BIOS so I could unlock my 550BE.
Someone had a thread in the overclocking forum about the temperatures & what was a good guideline as to the actual temps.
Old December 8, 2009, 07:55 AM
i'll search for that thread ,i must have overlooked it.
thanks
Old December 8, 2009, 08:08 AM
Cowboy's Avatar
From when I had an x2 550: Unlocking the other 2 cores really affected overclockability. I was able to hit 4ghz easy on 2 cores, but only to 3.6 on 4.
Old December 8, 2009, 08:18 AM
Here ya go Jay:
Phenom II X2 550BE (UNLOCKED)
Old December 8, 2009, 10:12 AM
Greg:That be what i'm looking for :)
Thanks
My $550 Build- Please check it out!!! jcmaz New Builds 4 October 7, 2009 07:21 PM
Phenom II 550 jcmaz CPU's and Motherboards 2 October 3, 2009 07:56 PM
AMD 550 unlocked to B50 X4 OC @ 3.7GHz 1.415v canmx120 Overclocking, Tweaking and Benchmarking 9 October 2, 2009 08:50 PM
