Old December 1, 2009, 12:59 PM
I'm really surprised that eVGA doesn't offer lifetime warranties on their "mainstream" chipset FTW parts.
Old December 1, 2009, 04:15 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Thanks all :)
bojangles - thanks, will get it updated. Wrong file name in there I guess..
kiwik - Kept VTT at 1.35v, but Ill probably drop it to 1.3v. I think it is very doable at only 200BCLK and 800Mhz mem. Gunna reboot and drop it right now, will report back after I run stability tests.
EaGle1337 - Well there wasnt much to complain about.. I needed something right?? The issue for me was i couldnt use my IDE capture card for BIOS screenshots. Regular user would just have to worry about IDE drives.
Old December 1, 2009, 04:49 PM
Eldonko's Avatar
WIC chart updated, cheers
Old December 1, 2009, 07:06 PM
Eldonko's Avatar
VTT at 1.3v was no go at the same vcore, testing 1.325v now
1.325v VTT no go either, back to 1.35 for me!
Old December 2, 2009, 08:08 AM
kiwik's Avatar
See what I meant :p
I have almost the same setup and it needs 1.3625v for vcore, but a much safer 1.25v vtt.
3.8GHz with HT and passing LinX. Ram is at 1066 strap.
Old December 2, 2009, 09:12 AM
Eldonko's Avatar
Most people seem to be running 1.35v VTT or even 1.4v in their setups so Im not worried about it. This thing is very solid at 4Ghz and I plan to run at that speed until I setup my next board. I could drop VTT a bit and increase vcore but I dont really see a need.
Old December 2, 2009, 06:58 PM
kiwik's Avatar
It's also that 4GHz is hard on the Hyper212 + with 2x 1200RPM S-Flex, hitting 100C and crashing in OCCT eventually. Hyperthreading adds a good 10-15C on each core, that's quite a lot.
Nothing you'd have to worry about with your WC.
Old January 26, 2010, 08:24 AM
I'm able to clock my i5 750 @4.2ghz (1.38v without vdroop)
This thing is just amazing~!
My another rig i7 920 with ASUS P6T just couldnt OC that easy.
I will be a EVGA motherboard buyer from now on ~!
Thanks for making me so happy EVGA
MSI P55-GD80 LGA1156 Motherboard Review Comment Thread MAC CPU's and Motherboards 10 October 21, 2009 02:17 PM
EVGA P55 Mobo Lineup Revealed + P55 FTW Preview Comment Thread SKYMTL CPU's and Motherboards 11 August 22, 2009 10:31 PM
EVGA X58 3X SLI Classified LGA 1366 Motherboard Review Comment Thread 3oh6 CPU's and Motherboards 82 June 4, 2009 07:47 AM
