-   -   Really Pushing The 920 To Its Limit ! (http://www.hardwarecanucks.com/forum/cpus-motherboards/25763-really-pushing-920-its-limit.html)
JORD4N November 22, 2009 09:11 AM
OK ill going to say im a right noob at overclocking :biggrin:
When i take my Bus Speed Over 212.5 x20+1 With Turbo=x21
My pc will just CRASH :blarg: Or BSOD
Im running Corsair Dominator's at 1866mhz-Stock, Yeah i got better ones then the 1600mhz before :thumb:
Anyway around this...? i wana hit 4500ghz So Bad :bananafunky:
Just to add the CPU temp is not an issue that i know of anyway..
http://img695.imageshack.us/img695/3316/rig.png
SugarJ November 22, 2009 09:50 AM
Take out 6gb of ram. It's very hard to overclock with 12gb on board. But you've got a 2.66 ghz chip running at 4.4. What's the issue? I'm having trouble cracking 4.0 with mine.
3.0charlie November 22, 2009 10:14 AM
Though I think a Vcore of 1.49V may become an issue...
JORD4N November 22, 2009 10:27 AM
Just did 1.5, 1.65 & 1.70 Nope still same :sad:
jcmaz November 22, 2009 10:44 AM
honestly, are you going to sense that extra .1ghz???
Arinoth November 22, 2009 10:46 AM
I would not want to go that high on the vcore in fears of actually frying my chip or motherboard
geokilla November 22, 2009 10:48 AM
Your voltages are insane even if you're water cooling. Only a matter of time before something dies.
martin_metal_88 November 22, 2009 10:51 AM
It smell like soon CPU frying:) Vcore is way to high!
Arinoth November 22, 2009 10:53 AM
You also have the wrong temperatures for the cpu you should be worry about highlighted as well. They aren't those low ones, they are the ones beside it named CPU core 1 to 4
Zero82z November 22, 2009 10:55 AM
If you want your CPU to last more than a few days without shitting its pants, keep your Vcore below 1.5V.
