  #21 (permalink)
Old November 22, 2009, 03:24 PM
gingerbee's Avatar
ah an h50 them 920 put out a little too much heat for them i think what's your load temps at
EDIT i5 are quads they just don't have hyper threading
  #22 (permalink)
Old November 22, 2009, 03:25 PM
MpG's Avatar
MpG MpG is offline
While I don't think it's your main concern for overclocking, your idle temps seem high. Are you sure you're getting good heatsink contact? My own 920 idles at around 35-45*C, and it's at 4.5GHz. It's on a good watercooling system, but that doesn't usually make a huge difference for idle temps. It's possible that you're using too much or not enough thermal compound.
Your latest screenshot looks safe enough, I'd say. It should be obsolete long before you have any troubles. I'd still be curious what sort of temperatures you get under full load with something like Prime95 v25.9 or similar.
  #23 (permalink)
Old November 22, 2009, 03:28 PM
gingerbee's Avatar
same here 38c to 40c on all cores good water cool loop loads at 76c max ( that's the highest i have every seen )
EDIT this is just one review but it does not seems to handle the i7 too hot ha ha not like it's bad in any way. these chips just run hot Corsair Hydro Series H50 CPU Water Cooling Kit Review - Results, and a "What If" Scenario - Legit Reviews
  #24 (permalink)
Old November 22, 2009, 03:36 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Honestly, even with the H50 being an overpriced POS, those idle temps are high. I can just imagine what your 1hr Prime95 temps would be. High idle is bad, high 100% usage temps can cause thermal throttling (something you want to avoid).
Id yank the H50, clean off the TIM, apply some MX-2 and remount it. See if the temps are better....then drop another fan onto the H50 to help it out. I assume your pushing the hot air OUT your case right?
  #25 (permalink)
Old November 22, 2009, 04:10 PM
kendallcschm's Avatar
the temps are high... did you try increasing the bus speed??
  #26 (permalink)
Old November 22, 2009, 04:56 PM
With idle temps like that I would be fairly confident that even 10mins of linpack would push it close to 100c.
  #27 (permalink)
Old November 22, 2009, 05:45 PM
HaDeS
Guest
Posts: n/a
whats the h50 rated for anyway?
  #28 (permalink)
Old November 22, 2009, 06:22 PM
AkG's Avatar
AkG AkG is offline
NOT enough :)~
Its based on a mediocre Asetek design. Asetek rock at some things....integrated pump and water blocks w/ single bay rads are NOT one of them.
Good enough for dual cores....maybe a lower TDP quad but an high OC'ed 920 is pushing it way past its limits.
  #29 (permalink)
Old November 22, 2009, 06:49 PM
The H50 Comes with paste allready applied on... Hmm maybe its just crappy paste
Build Progress.
Brought...
Tick - Intel Core i7 920
Tick - EVGA X58 SLI LE Intel X58
Tick - Corsair 850W HX PSU
Tick - Corsair 12gb Ram 1666MHz
Tick - Corsair H50 Water Cooling
Tick - Corsair 800D Case
Tick - WD 1TB Hdd WD1001FALS
Tick - NZXT Sentry LX (Fan Controller)
Tick - Razer Diamondback, Mouse
Tick - Razer Lycosa, Keyboard
Tick - ATI 5870 Graphics Card x1
Need...
Untick - ATI 5870 Graphics Card x3
Untick - LG CH08LS10 Blu Ray
  #30 (permalink)
Old November 22, 2009, 06:53 PM
It's good quality Shin Etsu paste.
Help Pushing AMD 955 Black Edition Surfer_2099 Overclocking, Tweaking and Benchmarking 20 November 1, 2009 05:34 PM
Pushing the Limits Perhaps? Soultribunal Power Supplies 14 May 17, 2009 10:30 PM
How can I limit Bitlord...? Lamb Networking 21 April 24, 2009 06:59 PM
Pushing the PC gaming boundaries magictorch Press Releases & Tech News 0 November 16, 2007 07:45 AM
Help! Trouble!..pushing the FSB to high! francois methot Overclocking, Tweaking and Benchmarking 23 March 11, 2007 10:16 AM
