Old November 20, 2009, 08:44 AM
Efx Efx is offline
Default E8400 (E0) still worthy?
So i have this e8400 running at 4.2Ghz 24/7 with 4870x2. I use this rig mostly for gaming. I noticed that there isn't much gain in FPS when playing(1900x1200 max settings) while overclocked or at stock speeds (3.0Ghz). Is this normal? Would i see any gains from jumping to Q9550 for example?
Old November 20, 2009, 08:58 AM
MarkOne's Avatar
if you see no gain between a 4,2 ghz and 3,0 ghz...it's because it's your GPU the bottle neck... upgrading to a quad will only benefit games that can use it .. the Q9550 run more slow than your dual core, and will not overclock better.
Old November 20, 2009, 10:36 AM
headsh0t's Avatar
Yes, Mark is right. If you see no difference while overclocked, then it has nothing to do with the cpu, but it's the GPU. That's usually the case with gaming is the GPU. Most games don't use 4 cores anyways. What game are you playing that you need an increase in FPS from a 4870x2? Excluding crysis....
Old November 20, 2009, 06:11 PM
belgolas's Avatar
I have a second rig with a E8400 and with 5850 and it runs every game out there max settings at 1920 x 1200 including crysis but at 4xAA if you want smooth.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old November 20, 2009, 07:09 PM
Sir, be proud and set that 5850 on your sig
Old November 20, 2009, 08:38 PM
kingnubian's Avatar
I have an E8400 clocked @ 4.1Ghz paired with a 4870 and am very happy with the performance. Overclocking this puppy, over a year now, has finaly kept me from the perpetual upgrade cycle I was caught in, for now :-).
You should see a performance boost going from 3-4Ghz unless you are GPU limited or there is some other issue.
GOD Is Good
________________________________________
Intel i7-2600K @ 4.8Ghz
Asus Sabertooth Z77
16GB G.Skill Ripjaws Z (1866MhZ CAS9)
NZXT Kraken X60 CPU Cooler
2x Sandisk Extreme 240GB SSD (RAID 0)
Seagate 7200.12 500gig HD
Galaxy GTX660Ti 3GB
LG DVDR
NZXT Phantom 630 Case
Antec TruPower New 750W Power Supply
Old November 20, 2009, 09:29 PM
Ditto.. E8400 + 4870 = real good gaming..
Old November 20, 2009, 10:55 PM
Been a great combo for me for a long time now, considering how often I upgraded prior to getting the two!
Old November 22, 2009, 09:15 AM
Efx Efx is offline
Games are Stalker SOC and SC
Old November 22, 2009, 09:56 AM
MarkOne's Avatar
Did you say Stalker ? I have 2 pc with both a 4890 : a e8400 and a i5 ....I don't see any difference in stalker . I was using 2 X 4890 in crossfire..with a 24" , I remove one , because here too I see no difference. I don't play other game than Stalker. I own many other games I pay for , crysis, all the COD and many more.. I don't like them...
OC E8400 jay51 Overclocking, Tweaking and Benchmarking 13 January 8, 2010 07:53 PM
9800GT a worthy upgrade from 9600GSO 512? dimre01 Video Cards 8 August 7, 2009 11:54 AM
OC E8400 DavidDemise Overclocking, Tweaking and Benchmarking 4 August 16, 2008 10:38 AM
E8400 on ? Rapid-X CPU's and Motherboards 7 May 9, 2008 03:31 PM
