Old November 15, 2009, 05:32 PM
Logger's Avatar
Question ASUS P7P55D Pro & 8pin EATX12 with cap
Hi I just got an Asus P7P55D Pro mobo. The-8pin EATX12V plugin has 4 of the pins covered with a plastic cover. Do I take the plastic cover off and attach the 8pin-female power connector from the PSU?
Or just use the one 4pin power connector. I just don't know. I will be overclocking both the Intel Core i5 750 Quad Core and the XFX GeForce GTX 260 vid card. Thank you.
Logger
CPU---Intel Core i7 920 @ 3.7GHz, 1.28V,
Mobo--ASUS P6T Deluxe V2 X58,
Ram---Corsair XMS3 Dominator TR3X6G1600C8D3X2GB, DDR3-1600 CL 8-8-8-24,
GFX---BFG GTX 280,
HDD---2xWD 300GB Velociraptors, Raid0,
PSU---Corsair HX 1000W, modular,
Case--Mountain Mod U2-UFO, Black Powder Coat,
Sound-Sound Blaster X-FI Xtreme Gamer,
LCD---Samsung T260 25.5IN-1920X1200,
WaterCooling-Parts--MCP655 Pump,Thermochill 120.3 Rad, D-TekFuzion Cpu Block,
GPU waterblock EVGA GTX 280 Hydro Copper.
Old November 15, 2009, 05:33 PM
SugarJ's Avatar
If your PSU has an 8 pin, take the plastic off and use the 8 pin. The cover is there in case you only have a 4 pin EPS so you know what side to plug into.
Old November 15, 2009, 05:52 PM
Logger's Avatar
Thank you SugarJ, my psu has the 8-pin eps.
I just noticed the time of the reply, you have a very quick trigger finger SugarJ
Logger
GFX---BFG GTX 280,
Old January 2, 2010, 01:18 PM
Trial Member
Hi all,
I'm from france, this is my config :
- i5
- P7P55D LE
- 2go RAM (2x1go)
- Ati Radeon HD4890
- Power : Corsair 650W
When I Push the start button, nothing happens, but when i unplug the EATX12 8 pins, all is powered on but the POST screen doesn't appear, normal because these pins must be plugged.
Can someone help me please?
ASUS Introduces P7P55D Series Hybrid Motherboards FiXT Press Releases & Tech News 0 September 10, 2009 10:21 AM
ASUS P7P55D Deluxe Motherboard Preview Comment Thread SKYMTL CPU's and Motherboards 14 August 26, 2009 03:11 PM
40th Anniversary - Moon Map & Mission Re-Cap misterlarry Off Topic 11 July 20, 2009 06:14 PM
Gauging Interest: FS: Car Audio 2x15s, Amp, Cap, Box CMetaphor Buy/Sell & Trade 19 July 22, 2008 09:08 AM
