Old November 10, 2009, 05:57 AM
Default Droped My i7 on the floor :/
OK so i got my h50 water cooling back from the rma and i was cleaning the old thermal compound and i only ******* droped my cpu i was about 1m + off the ground it is wooden floor... are these things strong ? Theres no dammage from what i can see.
Build Progress.
Brought...
Tick - Intel Core i7 920
Tick - EVGA X58 SLI LE Intel X58
Tick - Corsair 850W HX PSU
Tick - Corsair 12gb Ram 1666MHz
Tick - Corsair H50 Water Cooling
Tick - Corsair 800D Case
Tick - WD 1TB Hdd WD1001FALS
Tick - NZXT Sentry LX (Fan Controller)
Tick - Razer Diamondback, Mouse
Tick - Razer Lycosa, Keyboard
Tick - ATI 5870 Graphics Card x1
Need...
Untick - ATI 5870 Graphics Card x3
Untick - LG CH08LS10 Blu Ray
Old November 10, 2009, 06:07 AM
my guess, if it realy dont have any physical domage, try it...
if it broken and dont have physical domage you can rma it to intel
Old November 10, 2009, 06:09 AM
gingerbee's Avatar
dead. hope it works most will not work after like a meter fall good luck on you. there was a member here a few months ago who dropped he's e8400 form a table it was dead as a door nail. there not really meant to take that kinda g-force
Old November 10, 2009, 06:18 AM
I would test it but my CORSAIR Ram in allready been returned and im waiting for the refund.
So far what has broke on my build is my.
Corsair Dominator Ram
Corsair H50 Water cooling [Leaked]
EVGA x58 SLI LE Motherboard
NZXT Fan Controller [3rd Fan did not have power]
Also my nzxt case... the 2back legs snapped off but i fixed them so not much of a prob.
WOW Now it might be my i7... God this build is really not working out for me is it.
Build Progress.
Brought...
Need...
Old November 10, 2009, 06:20 AM
bojangles's Avatar
May as well try it. It won't hurt anything. Overcurrent protection and other safety features will kick before anything bad happens.
Old November 10, 2009, 06:22 AM
Infiniti's Avatar
He doesn't have his ram to test it.
I don't think it would've done much, unless of course a bit chipped off. The CPU should be able to take the fall, since it's a solid piece.
Old November 10, 2009, 06:27 AM
Yea thats what i was thinking it seems solid so i would not o thought anything could bust due to it being coverd in solid metal... the green board as looks in tacked.
yea if the worst comes to the worst ill send it to intel no biggy.
Build Progress.
Brought...
Need...
Old November 10, 2009, 06:46 AM
gingerbee's Avatar
I can't see any damage so it ain't broken WHAT it's a micro processor the only way to tell is to test it does not matter what it looks like ( unless you have a clean room handy that and some very power micro scopes ) g-force is a chips enemy remember it not the fall that kills you it's the sudden stop ( good lick from the sounds of it you need. how did all the that stuff brake? )
Old November 10, 2009, 07:01 AM
Arinoth's Avatar
As long as none of the pins are bent it should be fine as it was not operating during its travel from point a to the floor.
Here I am: here I remain
Old November 10, 2009, 07:28 AM
MpG's Avatar
MpG MpG is offline
Intel chip - no pins on the CPU to bend. If there's no obvious physical damage, it should be just fine. Not like being rubbed on sandpaper for a couple hours, or crushed by an aftermarket heatsink hurts them any.
Desk or Floor? Signal2Noise Cases 38 September 17, 2009 05:49 PM
Killing floor issue ToXic Troubleshooting 9 August 31, 2009 05:01 PM
Killing Floor cmac79 Gaming 10 May 17, 2009 09:00 AM
ECS X58 Motherboard Ad Campaign - This will put you on the floor laughing Linus CPU's and Motherboards 9 November 21, 2008 09:11 AM
Prices of LCD panels fall through the floor: Inquirer Babrbarossa Display Units 1 March 16, 2007 12:39 PM
