Old November 10, 2009, 06:55 AM
bojangles's Avatar
Originally Posted by gingerbee View Post
dead. hope it works most will not work after like a meter fall good luck on you. there was a member here a few months ago who dropped he's e8400 form a table it was dead as a door nail. there not really meant to take that kinda g-force
I can't see any damage so it ain't broken WHAT it's a micro processor the only way to tell is to test it does not matter what it looks like ( unless you have a clean room handy that and some very power micro scopes ) g-force is a chips enemy remember it not the fall that kills you it's the sudden stop ( good lick from the sounds of it you need. how did all the that stuff brake? )
Changing your mind are we?
Old November 10, 2009, 07:02 AM
im sure his 2nd post he was being sarcastic . didn't change his mind,..i could be wrong tho
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old November 10, 2009, 07:12 AM
Gellidius's Avatar
after i got my pc up last spring, the only thing that was broke was me...
Jacques
Ego cogito, ergo deus non est.
Old November 10, 2009, 07:55 AM
Eldonko's Avatar
Hardware Canucks Reviewer
It's probably fine
Old November 10, 2009, 08:23 AM
gingerbee's Avatar
Bingo. there all guessing saying if it looks ok it should work . the looks of a chip don't mean anything it's how hard the stop was from the fall.
the only way to find out will be to test it end of story
( the reason i said dead is because if i drop a cpu on the floor off of my table or from table height i don't really expect it to work afterward's. so when i try it out if it works then great if it doesn't then i am not that pissed cause it my fault ) good luck on your build
Old November 10, 2009, 11:03 AM
headsh0t's Avatar
I'm looking forward to seeing the results :)
Old November 10, 2009, 11:55 AM
biff's Avatar
I'll bet it's OK though I suppose depending on how it landed it's possible he might have cracked the die. Only one way to find out....
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old November 10, 2009, 01:05 PM
Would really like to see the if the CPU is still working. I would be amazed if it did, but at the same time, the chips are packed so it might still be functional.
  #19 (permalink)
Old November 10, 2009, 01:51 PM
Most likely no problems.
At any rate, Intel's RMA process is A++++, would recommend again!
I've RMA'd about three CPUs with Intel and every time it was very very very quick turnaround (granted I two-day ship it to Intel).
heatware
  #20 (permalink)
Old November 10, 2009, 04:44 PM
belgolas's Avatar
I would say it most likely survived because of the short distance, it is very light, and is built strong. Now it could easily have a small micro fracture that could render it more useless than a coaster. Although CPUs are fun to take apart......
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Desk or Floor? Signal2Noise Cases 38 September 17, 2009 05:49 PM
Killing floor issue ToXic Troubleshooting 9 August 31, 2009 05:01 PM
Killing Floor cmac79 Gaming 10 May 17, 2009 09:00 AM
ECS X58 Motherboard Ad Campaign - This will put you on the floor laughing Linus CPU's and Motherboards 9 November 21, 2008 08:11 AM
Prices of LCD panels fall through the floor: Inquirer Babrbarossa Display Units 1 March 16, 2007 12:39 PM
