Old October 29, 2009, 07:53 PM
Originally Posted by geokilla View Post
I somewhat agree with what he said. Check to make sure that the HSF is secured properly and that you got enough TIM on it.
How long did it pass Prime for? What's the voltages? How's the airflow? All that contributes to your temperatures.
yes the 212 needs xtra TIM
and need a verry slight lapping with 1000 grit
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old October 29, 2009, 10:18 PM
Thanks for the info all.
I think airflow is the problem... I've reseated it 5 times, using two different compounds, and they're still the same. I even added a 80mm fan, which helped a bit inside. I did some more tweaking, lowered the volts a bit, and I got it down to 72c full load. Hopefully using 72c 24/7 won't be a great deal.
I really need a new case. It's very cramped in there, lots of wires from the PSU blocking space. I even have 6 HDD's in there.
Coolermaster Hyper 212 Plus AMD Installation & Clearance sswilson Air Cooling 76 November 4, 2013 06:42 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Push/Pull config - Hyper 212+ Owners JMCD Air Cooling 3 October 11, 2009 09:01 PM
AMD build help (hyper 212) bumfloss New Builds 6 September 9, 2009 03:34 PM
