Old October 27, 2009, 10:13 PM
Default unlocking PhII 550BE
Well finally upgraded this htpc with new mobo,cpu,ddr3,60gb-vertex.
Im trying to unlock the 2 other cores,is it as simple as changing ACC to Hybrid?
is there more changes needed?
It shows 4 cores in bios and boots as a x4 Denab when in hybrid mode but only 2 cores in taskmanager/prime95..am i missing something here?
Mobo's a GA-MA785GMT-UD2H with orig. F1 BIOS
Thanks for any help
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old October 27, 2009, 11:35 PM
odis172's Avatar
Is the SB710 Southbridge able to do that successfully? Ive read that the sb750 is recommended.
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old October 27, 2009, 11:38 PM
I have no idea TBH
just wanted to know if ACC was all that needs changing..
Edit:CPU-Z Shows SB750 hmmm
Old October 28, 2009, 10:53 AM
Cowboy's Avatar
sb710 will work fine. My board (which has sb710) unlocked my chip to 4 cores and I get 4 cores shown in task manager (on win7) and in cpu-z; 4 cores are even reported in the bios as well.
Old October 28, 2009, 11:11 AM
Perineum's Avatar
I flipped two switches to unlock that exact processor.
Hybrid and then auto.
Old October 28, 2009, 11:47 AM
I couldn't open the page at work, but this may be of interest:
unlocking 550 w/ Gigabyte GA-MA785GMT-UD2H - [H]ard|Forum
Old October 28, 2009, 12:25 PM
There were a few extra things I had to do to get mine to unlock, one I think was disable cool 'n quiet. I'll poke around in my bios when I'm done work if I have time and let you know my settings. I've got it unlocked and OC'd to 3.8 right now(on air :D )
Old October 28, 2009, 12:57 PM
settings would be great,wondering if updating BIOS to F2 will help,i managed to find it on a European site..
this cpu oc's amazingly well, im happy with it as a dual core but quad would be a bonus ..
Old October 29, 2009, 02:01 PM
What is a reasonable maximum temperature ?
Are you guys using coretemp?
Are you adjusting the offset or leave it at 0?
currently im at
3.8@ 1.4v
37 idle
54 load
I'm still using the stock cooler but will be changing to AC freezer and give more volts .Is 1.5v safe for 24/7 use if temps allow?
Thanks
Old October 29, 2009, 02:37 PM
gingerbee's Avatar
hell nice temps and volts you can go higher anything under 65c is cool jmo
X2 550BE Unlocked Caldezar CPU's and Motherboards 9 October 9, 2009 09:13 AM
PhII 955 WC Characteristics sswilson CPU's and Motherboards 12 October 1, 2009 08:36 AM
PhII 955be wonky sensors? sswilson CPU's and Motherboards 11 September 29, 2009 12:53 PM
AMD Phenom II X3 710 Unlocking. Turn it into an Engineering Sample geokilla Overclocking, Tweaking and Benchmarking 3 July 2, 2009 07:58 PM
bfg 7800 gs oc agp unlocking krull Video Cards 4 June 1, 2009 05:28 AM
