Old October 29, 2009, 03:23 PM
Silvgearx's Avatar
Originally Posted by gingerbee View Post
hell nice temps and volts you can go higher anything under 65c is cool jmo
your are forgetting that 70C should be max for these chips.
AMD chips don't like heat
AMD x2 550 @ 3.4ghz
1.3v
idle 22-23C
29-31C 24hour load.
And when you open AMD overdrive it will tell you the max safe volts for your CPU
I leave the ACC % stay at 0%
I read somewhere that the higher the % the higher overclock you can go and the lower values should allow for lower voltages and power.
Old October 29, 2009, 03:58 PM
gingerbee's Avatar
I have always run any amd chips i have safely under 70 with no problems .jmo
X2 550BE Unlocked Caldezar CPU's and Motherboards 9 October 9, 2009 09:13 AM
PhII 955 WC Characteristics sswilson CPU's and Motherboards 12 October 1, 2009 08:36 AM
PhII 955be wonky sensors? sswilson CPU's and Motherboards 11 September 29, 2009 12:53 PM
AMD Phenom II X3 710 Unlocking. Turn it into an Engineering Sample geokilla Overclocking, Tweaking and Benchmarking 3 July 2, 2009 07:58 PM
bfg 7800 gs oc agp unlocking krull Video Cards 4 June 1, 2009 05:28 AM
