Old October 23, 2009, 10:37 AM
Default CPU temps?
Hey guys,
I just finished my first build yesterday and have a question about the cpu temps.
I have an evga x58 3x sli motherboard, intel i7 920, and a cooler master hyper 212+ to cool it.
Here are my temps at idle with NO overclocking. Are these temps too high? Also cpu cores 1 and 3 are alwasy 1-3 degrees hotter than 1 and 2, why is that?
I will post build pics later.
Old October 23, 2009, 11:39 AM
Arinoth's Avatar
They are alright idle temps but what really will matter is your full load temps
Here I am: here I remain
Old October 23, 2009, 12:12 PM
Soultribunal's Avatar
As Arinoth said, Load temps really do matter, however it is perfectly normal to have Cores a few degrees off from each other. My Core 2's in both my Old build and HTPC had ones that were around 4 degrees difference at times.
As well even when your computer idles it does have a minimum useage of one or two cores so that can make for the difference as well.
ST
www.realhardwarereviews.com
Old October 23, 2009, 12:26 PM
Ok thank you both. Is there a tool that lets me test my load temperatures?
Old October 23, 2009, 12:41 PM
Use the latest Version of CoreTemp and Prime95 to put full load on the cores.
That will get you a good idea of what your Load temps will be like.
Regards,
ST
Old October 23, 2009, 12:47 PM
Sushi Warrior's Avatar
Prime95, OCCT, Intel Burn In.
Old October 23, 2009, 01:36 PM
I've found that LinX is a really good program to make your CPU scream (crash quickly if it's not stable)
OCCT is a pretty good tool too, you can compare the load graph to temp graph, etc.
can lapping your cpu raise temps up? Shadowmeph CPU's and Motherboards 5 August 5, 2009 01:15 PM
watercooled cpu temps on non OC system Shadowmeph Troubleshooting 13 July 16, 2009 12:08 PM
which temps are correct? cpu, cpu core1? Shadowmeph Overclocking, Tweaking and Benchmarking 4 July 13, 2009 06:23 PM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
HDD, CPU temps too high? donimo HTPC Systems & Software 12 June 6, 2008 09:34 AM
