Old October 19, 2009, 06:47 AM
Originally Posted by Sagath View Post
Return Merchandise Authorization. Basically it is something companies do to track warranty returns to them. I would go to evga.com and set one up. You want to return this and get a new one asap. Be sure to EXPLICITLY specify that this was NEW NEVER USED straight out of the box bent pins. Usually warranties dont cover bent pins, so you might have a fight on your hands. EVGA is pritty good tho, so you're better off then if it was any other company.
For your second question: Bent pins can lead to broken pins, yes, if you try to correct them. In this case, dont try to correct them, get the RMA set up and let EVGA deal with it
Edit: Ninja'd Not once, but twice!!
yeah i think im going to do that, just going to go look on evga.com for it now...
Also do they charge me postage ? reason being i allready payed $45 postage usa to england for this.
Or does a courier come to my house and pick it up like what they do with the xbox 360's "RRoD"
Old October 19, 2009, 07:06 AM
Arinoth's Avatar
You have to pay for postage to them. They may however have a European repair centre, though they will tell you if the RMA is approved (they tell you where to ship it)
Here I am: here I remain
Old October 19, 2009, 07:18 AM
JD JD is offline
Foxconn sockets strike again! This time on LGA1366
That sucks though, you imported the board and now you have to RMA it. I'm guessing that might be a bit of a hassle.
Old October 19, 2009, 07:36 AM
Sushi Warrior's Avatar
I thought EVGA doesn't use Foxconn sockets, at least not on P55.
Old October 19, 2009, 08:58 AM
JD JD is offline
Originally Posted by Sushi Warrior View Post
99% sure EVGA doesn't use Foxconn sockets, at least not on P55.
Well this X58 board clearly does. Says Foxconn on the cover.
And only the P55 FTW doesn't, the other boards are hit and miss I believe.
Old October 19, 2009, 11:51 AM
Update: Just apply'd for an rma now hopefully if all goes well i should get a new one.
As this was not my fault it was evga's
Old October 19, 2009, 11:53 AM
Wow. I totally missed that....
Old October 19, 2009, 12:37 PM
  #19 (permalink)
Old October 19, 2009, 12:39 PM
In response to Jdrom. Thanks to the edit button, no one will ever know..... wait
  #20 (permalink)
Old October 19, 2009, 01:40 PM
FiXT's Avatar
Hall of Fame
I wish you the best of luck with your RMA.
Getting an RMA for bent pins is unlikely to be approved. End user physical damage is the cause a large majority of the time and consequently most manufacturer's downright refuse.
The fact that you bought it recently may work in your favour. But you stated that it had been in the mail for 4+ weeks. I highly suggest you provide them with proof, such as the tracking number along with the invoice.
Otherwise they will merely look as though you purchased it more than a month ago, and that is definitely far to long to report a DOA incident
[WTB] AMD Socket 939 and 754 CPU FrankyG Buy/Sell & Trade 6 April 11, 2009 09:14 AM
FS: AMD socket A mobo and cpu combo yamawho Buy/Sell & Trade 0 November 1, 2008 08:43 AM
Intel socket 478 cpu sale yamawho Buy/Sell & Trade 3 November 1, 2008 08:17 AM
WTB: Socket AM2 AMD Athlon X2 / Phenom CPU nakano2k1 Buy/Sell & Trade 3 October 20, 2008 03:43 PM
RMA your board...get thermal compound on your cpu socket! Mibs Troubleshooting 8 September 24, 2007 04:58 PM
