Old October 20, 2009, 09:57 AM
misterd's Avatar
Originally Posted by bissa View Post
I can get my 2.5 to 3.66 and be stable but for long term constant 100% (like 5-8 hours straight) the temperature starts getting a little worrying. and that did make a noticeable change in starting larger programs like WoW and vector works, but I generally just keep it at 3.2 which still makes a nice change while not making it possible to make pasta on the heat coming off my heat sink.
mmmmmmmmmmmm pasta (homer voice)
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old October 20, 2009, 09:59 AM
bissa's Avatar
what? I probably could, I was hitting 80, but it would only hit anything above 70 after running for at least 2 hours.
Strong like hummingbird, swift like oak.
I'm sorry july, I couldn't see you behind all that feruary.
Old October 20, 2009, 02:37 PM
Silvgearx's Avatar
not just bragging.
overclock saves $$$$.
buy a lower clocked same batch CPU, overclock it to highest-end CPU clock speeds.
Old October 20, 2009, 03:03 PM
On a good machine yes overclocking helps.
But the benefits vs overclocking do reach a hiatus depending on what you do.
When I had my e8400 I saw little gains in performance between 3.6 and 4.0ghz relative to FPS in games.
Old October 20, 2009, 03:20 PM
When you no longer get a gain from a CPU speed increase, your next limiting factor is the GPU.
Old October 20, 2009, 03:26 PM
I'm aware of the limitations of my 8800GT and I know with a larger gpu I would see more benefit.
Old October 20, 2009, 05:07 PM
But if you were to upgrade to lets say a 5870 or a gtx 295 and didn't overclock your cpu it would be a bottleneck instead of a gpu like the 8800 Or so i've heard
Old October 20, 2009, 05:09 PM
Exactly.
  #19 (permalink)
Old October 20, 2009, 05:11 PM
Soultribunal's Avatar
Originally Posted by Arinoth View Post
Yep, its half about bragging rights and the other half is the performance increase in cpu intensive tasks (as it is able to do them faster/quicker). That's about it
What chip do you have at 3.6 ST?
Suicide Run on a Kuma Cored AM2+ :)
It should have actually read 2.7 - 3.6 but my brain is faster than my hands.
ST
www.realhardwarereviews.com
  #20 (permalink)
Old January 26, 2010, 08:34 AM
gaming is my only reason to OC but that is just me
Overclocking HELP please Crysisfan11 Overclocking, Tweaking and Benchmarking 1 May 27, 2009 10:15 AM
About Overclocking blogz101 Overclocking, Tweaking and Benchmarking 0 July 28, 2008 07:17 PM
Overclocking P4 1.8 Kassela Overclocking, Tweaking and Benchmarking 1 December 27, 2007 12:28 PM
Need help overclocking further Kessler Overclocking, Tweaking and Benchmarking 15 December 5, 2007 06:09 PM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
