Old October 18, 2009, 08:49 AM
Default mouse lock up or froze
not sure where this go... but where the hell this go? no general hardware section?
problem: mouse lock up
whenever my mouse lock up.... my cpu have hard sound. i even plug in plug out mouse wire and make sur eit fit tight but still no work. everytime it happend i had to force shut down. it happend once every 4 days average.
everything is fine jus that my mouse wont move.
whats the deal? what cause it? cpu problem?
also at times it have light lock up for like 1sec. like when surfing moving mouse and sometimes mouse wont move for 1sec. playing fps games too have this problem. my mouse is dust free.
x2 4400+
3gb ram
8800 gts 512mb
windows vista 32bit
Old October 18, 2009, 09:58 AM
gingerbee's Avatar
dead mouse maybe it happens
Old October 18, 2009, 10:21 AM
forgot to mention. that have been nailed down. not the problem. i plug in other mouse and i still get the 1sec pause.
cpu tone sound harder and louder when it lock up. somethign wrong with the system..... any ideA? anymore ideas?>
Old October 18, 2009, 10:46 AM
gingerbee's Avatar
sounds like drivers to me
Old October 18, 2009, 05:01 PM
I've sen that occasionally occur with users running Norton 360.
Old October 18, 2009, 05:42 PM
sswilson's Avatar
When you say "the cpu sounds louder".... are you talking about the cpu fan? Sounds to me like your cpu is overheating which is causing the whole system to lock up.
Is this a desktop or a laptop? I had a similar problem with my P4 laptop after about 3 years of use.... I ended up having to strip it down to clean out the crap from the heatsinks and fan exhausts/intakes.
Old October 28, 2009, 05:39 PM
man i really need solution on this. it is annoying! imposible to game on it! get 0.97sec mouse pause every 7min. but i dont really game on pc anymore. console is where its at. pc gaming is dead.
yeah its a desktop. yeah i think it is the cpu fan that sound louder or the whole area of the cpu. whenever it pause it have louder db noise then back down to normal once it stop.
also i was surfing recently and all sudden it click "file" on the browser for me! what the hizzzz!!!
i have never taken out cpu out before. but that might be last thing will try to do. does anyone know any other posibility of why my desktop computer is:
- mouse freeze for 0.97sec every 7min with cpu noise raisen
- mouse click itself on "file" browser
driver issue? hmm any particular driver issue? cause i reformat before and everything should be clean. i dont think its virus either.
Old October 28, 2009, 05:57 PM
bojangles's Avatar
OMG...as much as I'll try to help you I am totally confused by what you're saying.
Did you clena the mouse?
Reinstall drivers?
Clean the CPU fan out?
Do a disk cleanup?
Anyway, how the hell do you know it's 0.97 seconds pause, every 7 minutes? Just by reading that makes it feel like a spam thread...
Old November 3, 2009, 12:52 AM
sometime when i browse site and it scroll page down itself.
i have not clean cpu fan.
Old November 3, 2009, 02:29 AM
sswilson's Avatar
If the CPU fan is ramping up to 100% when you try to do fairly simple functions then the first place I'd check would be idle temperatures on your PC. Sounds to me like you might have a bad contact between the cpu and the cooler which is causing your PC to freeze due to overheat.
Total computer lock up, seemingly random Menello Troubleshooting 11 January 28, 2009 08:27 PM
Can we get the ability to lock or rename our threads in the B/S/T section? S_G Suggestions & Feedback 6 October 22, 2008 07:04 PM
Hard lock JD Troubleshooting 24 October 14, 2008 07:29 PM
Lock Computer Problem Mars O/S's, Drivers & General Software 2 July 18, 2008 03:44 AM
New computer always froze dracozhu Troubleshooting 1 May 22, 2008 05:35 PM
