Old October 17, 2009, 09:28 PM
Default CPU cooler
Hey guys,
I got the evga x58 3x sli motherboard (132-BL-E758-A1) and i need a cpu cooler.
Which is a better cpu cooler for i7 920, the CM hyper 212 plus or the CM Hyper N 520?
Newegg.com - COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-GP 120mm "heatpipe direct contact" Long life sleeve CPU Cooler - CPU Fans & Heatsinks
Newegg.com - COOLER MASTER Intel Core i7 compatible Hyper N 520 RR-920-N520-GP 92mm Sleeve CPU Cooler - CPU Fans & Heatsinks
Please keep in mind it needs to fit the evga x58 3x sli motherboard just mentioned.
Thank you.
Old October 17, 2009, 09:30 PM
Sushi Warrior's Avatar
I would strongly suggest the 212+ unless you have a small case.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old October 17, 2009, 09:46 PM
Will the 212 plus fit on the evga x58 3x sli motherboard? I heard that some dont fit do to its tall mosfet.
Old October 17, 2009, 09:49 PM
sswilson's Avatar
I've got some images in here... Coolermaster Hyper 212 Plus AMD Installation & Clearance if you want to judge the clearance yourself. (not the same motherboard).
Old October 17, 2009, 11:07 PM
It looks like it may fit. Does anyone have the evga and hyper 212 + that knows for sure?
Old October 18, 2009, 08:43 AM
Nobody has both of these?
Old October 18, 2009, 10:49 AM
gingerbee's Avatar
check out frostytech for the hyper 212 FrostyTech - Best Heat Sinks & PC Cooling Reviews
I don't see the n520 on the temp list here Coolermaster Intel LGA775 Final Heatsink Temperature Comparisons - Hyper 212 Plus FrostyTech Review
But there a good review here Cooler Master Hyper N520 CPU Cooler Review
Well after checking it out for temps it seems that the hyper 212 is better
Old October 18, 2009, 12:08 PM
Frosty-tech is a joke.
Old October 18, 2009, 12:27 PM
I have a Evag classified with a
TRUE but it can't for e-w due to nb. This Is partialy due to te fan clips sticking out
like half a cm tho. Not sure if that helped but just a comparison
Old October 18, 2009, 01:28 PM
I guess ill just have to buy the hyper 212+ and hope it fits the evga x58 3x sli. :)
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
