Old September 1, 2007, 02:13 PM
belgolas's Avatar
I was having overheating problems on my build. But all I had to do is reset the heatsink and the problem went away.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old September 1, 2007, 08:59 PM
Oh wow, I ran Orthos Beta for about 25 minutes, and it would reach around 85 degrees, and I'm afraid to let it go any higher. Ahhhhh I don't want my new comp to be destroyed in a few days... ><
Old September 1, 2007, 09:26 PM
Omg! BLAHHH, after the Orthos test, my cpu area is starting to make a hitch pitch buzzing noise, I dont think it's the fan because it makes the noise at any fan speed. Also when applications are loading, the noise stops, and comes back on once the loading is finished. weh.. whats happening?
Old September 1, 2007, 09:31 PM
3oh6's Avatar
Hardware Canucks Reviewer
well your load temps haven't changed so you still have a mount issue i suspect. as for the high pitch noise, that is likely your motherboard. odd that it stops when there is a load and comes back when it goes to idle. its usually the other way around.
Old September 1, 2007, 09:32 PM
JD JD is offline
Maybe you've fried a capacitor/MOSFET/whatever else? Those temps are through the roof. Either you have the worst case air flow ever, aka none, or you have installed the heatsink wrong.
I wouldn't be running my computer at 85C. If I saw that, I'd kill the power ASAP. If the CPU is pumping out 85C of heat, imagine what all the other components around it are running at...
Old September 2, 2007, 05:11 AM
sswilson's Avatar
What part of the country are you located in Song?
If you're down this way I could drop in and slap that AC 7 Pro on it to see if it's a HSF problem.
Old September 2, 2007, 09:13 AM
I live in Mississauga, Ont
Old September 2, 2007, 05:02 PM
Well, alright, thanks everyone. I believe I got my CPU's temperature to a decent temperature. I readded thermal paste (used Arctic Silver 5).
  #19 (permalink)
Old September 2, 2007, 05:07 PM
JD JD is offline
A lot better but still a bit high for stock I'd say.
  #20 (permalink)
Old September 2, 2007, 05:49 PM
cdn_Madrach's Avatar
I would say that if your temps dropped 20 degrees just by re installing your hsf then the problem is either with how you are applying the thermal compoud or how you are installing the heatsink itself or both....just my 2 cents.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Laptop temp killerklown Mobile Computing 7 March 6, 2008 01:32 AM
E6750 temp help? jasonmoreau CPU's and Motherboards 18 January 23, 2008 04:07 PM
Fan Control and temp sensors. chibi_man Water Cooling 3 October 4, 2007 07:16 PM
CPU Temp?? BALISTX CPU's and Motherboards 7 August 22, 2007 02:19 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
