View Poll Results: What do I do about the Silent Pipe
Huck it! 0 0%
Install it 0 0%
Don't install it!!! 4 66.67%
I am Canadian! 5 83.33%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old October 11, 2009, 01:08 AM
Default Silent-Pipe - newbie
Silent Pipe
Whats up with this hybrid Silent-Pipe2 on my Ex58 Extreme Gigabyte motherboard?
It says thermal, but right under that, in the user manual, it starts going off about water cooling. Is this a system I can only use with water cooling, and should exclude the silent pipe until im ready for water cooling?
Or is it needed even if I'm running on air?
I understand it's used for cooling the north and south bridge.
I could use a little heads up.
Hello!
My name is Caesar and I'm posting in Thunder Bay ON
I'm finally building my own rig! I've bought computers before, but here now, I am building a rig!
Just rocking an i7 920 with some Trichannel Gskills on a eX58-Extreme gbite mobo! I plan to learn some more and sometime develop a water cooling system, and a light show!
All the bes
t.
Caesar
Old October 11, 2009, 02:03 AM
1Tanker's Avatar
The chipset cooler can be run in a water-cooling loop, if you want. It can also be used without water-cooling, by just leaving it and running it as it stands. The basic included chipset cooler contains a heat-pipe..connected to the VRM/MOSFET sinks, so it can cool the chipset on it's own. The "extra" silent-pipe crappola isn't necessary, and just adds bulk and complexity to your cpu-socket area. I would leave the "baggage" off. GL
Old October 11, 2009, 08:48 AM
It's useless. Yes, it will cool your northbridge better, but it's really unnecessary and just adds extra bulk/is a pain in the ass to deal with.
Old October 12, 2009, 12:38 AM
I'm glad you guys came around. Thanks again for the info. I did install the system though, as I thought it was cool.
Tags
silent pipe , silent-pipe ex58-extreme
remounting heat-pipe assembly question SmogTown CPU's and Motherboards 1 January 12, 2009 12:22 PM
Newbie here. kav New Builds 78 November 6, 2008 08:04 AM
Newbie To Dc jinthabestmc Off Topic 1 June 6, 2008 02:28 AM
MSI P45D3 "cinco pipe" flashy cooling Babrbarossa CPU's and Motherboards 5 March 19, 2008 07:22 PM
