Originally Posted by oblisk I'm still on XPSP3 x86, would I see much improvement with 4?
How far do you think I can take it? |
I'm not even 100% sure that you can run a Yorkfield on a i965...can you? If you can, you have to watch out for the FSB-hole between ~360-400FSB. So, you either have to run over 400FSB(3.4GHz), below 360FSB(3.06GHz)...or use a lower multi to get over the 400 hump. I know my Q9550 didn't like to run much over 3.4/400FSB on my GA P35-DS3L(P35), but with the P45(P45-UD3P)...the sky's the limit...or cooling in most cases.
