Old August 28, 2007, 04:35 PM
3.0charlie's Avatar
Exclamation I'm lost in the AMD sockets....
First time I have ever worked with AMD cpus, and I'm totally lost with the Processor terminology...
A friend of mine as an Acer desktop with a Sempron 3200+ on socket AM2 (confirmed with CPU-Z). Now, since I know sweet-f$%#&*^-all about AMD, I need your help.
What is the best bang-for-the-buck AMD AM2 cpu, to replace the Sempron?
Thanks for your help.
John
Old August 28, 2007, 04:38 PM
sswilson's Avatar
If money is a consideration, probably around the 4200 X2 DC chips, otherwise... they're up to a 6200 X2 I think.
Old August 28, 2007, 04:47 PM
Amon's Avatar
For under $200, the X2 6000+ is one of AMD's most powerful processors at 3.0GHz. At about $150, the X2 5200+ 2.6GHz is another hard hitter. I remind you that these are 1MB L2 processors. The X2 4600+ 2.4GHz seems like an *okay* choice at around $120, though has a 512KB L2 cache. However, from what I can see, bang-for-buck actually increases as you move towards higher end processors...
In practice, all of AMD's processors are pretty much bang-for-buck units. I'm not a follower of AMD's X2 family, but I could tell you more if you wanted to know about Socket-939 units.
Old August 28, 2007, 05:12 PM
3.0charlie's Avatar
Thanks to both of you. I did forget to add that money is a consideration. It is a budget build after all, since the whole computer cost 485$ (w/taxes), including a 17" LCD monitor...
Which processor would best replace the 3200+, adding to the fact that a graphics card will be added too (most likely a X1900, though the X1650 is also considered)? Is the X2 4600+ a good choice?
John
Old August 28, 2007, 06:23 PM
3.0charlie's Avatar
One more thing: is there another name for the AM2 socket? 939, 940? Or are those different sockets and not compatible between each other?
Old August 28, 2007, 07:42 PM
sswilson's Avatar
Those are three different socket choices.
939 is AM2's predecessor, and I believe (I stand to be corrected....) 940 was one of their server sockets.
If it's got DDR2, and is an acer, chances are that it's AM2.
Old August 28, 2007, 07:50 PM
3.0charlie's Avatar
Thank you. Clears a few clouds.
It has DDR2, is an Acer and CPU-Z confirmed that it is an AM2 Sempron 3200+. I believe that I have found a nice CPU: a 4600+ for 105$ on eBay. Good deal?
Old August 28, 2007, 07:54 PM
Supergrover's Avatar
I could be wrong as I never got to play with one but 940 was only certain Optys and FX.
R.I.P.
Old August 29, 2007, 10:45 AM
Amon's Avatar
Yup, 940 was the older workstation and server socket. The earlier Athlon FX also used 940 (strangely), therefore senselessly requiring registered DDR memory.
Not that bad of a deal, although DirectCanada.com sells that processor for $109.66 in the retail box (meaning it comes with factory heatsink and paperwork). Be sure that you're looking for the AM2 4600+ because that same processor was also available for 939 before it.
Old August 29, 2007, 02:13 PM
belgolas's Avatar
If you want to find outhow powerfull a CPU is then check out
CPU Charts | Tom's Hardware
They also have other charts.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Woman sues Geeks squad 54M: lost laptop Babrbarossa Press Releases & Tech News 5 February 15, 2008 09:05 AM
Lost Planet omgwtf Gaming 6 September 11, 2007 10:46 AM
im lost Rapid-X Video Cards 4 July 24, 2007 03:42 PM
Lost Planet: Extreme Condition mo' power Gaming 0 June 4, 2007 04:09 PM
FREE HL2: Deathmatch, and HL2 Lost Coast flclisgreat Off Topic 3 June 2, 2007 04:21 PM
