Old October 5, 2009, 03:19 PM
Default Core 2 duo E6400 vs Core I5 750
Hello,
I currently have an E6400. If I would upgrade to a core I5 750 (changing MB, CPU and RAM) would I see a good difference with games and other programs? (I have GTX 260)
Or maybe I would just need to OC that CPU by changing the heatsink on it (I have Intel heatsink). My MB is a GA-965P-DS3.
Thank you very much
Old October 5, 2009, 03:22 PM
JD JD is offline
I'd think you'd see some very noticeable gains in overall system performance.
And if you do anything at all that's multithreaded (video encoding comes to mind), then you'll see massive gains there.
Old October 5, 2009, 04:04 PM
3.0charlie's Avatar
I had a customer doing that same upgrade about 1 month ago - he couldn't believe the speed difference.
Hydro-Quebec is salivating...
Old October 5, 2009, 06:11 PM
Sagath's Avatar
If you dont have a SSD, you can probably get away with a $250 upgrade that will give you equal to, if not more, performance depending on what you're doing with the PC.
But yes, either way you'll be happy.
Old October 5, 2009, 06:31 PM
The core i5 will crush what you have right now, it goes on par with the core i7 920 sometimes. For cheaper.
Old October 5, 2009, 06:34 PM
In day to day use I noticed no difference going from a dual e8600 to a quad 9550.
You could probably just overclock your cpu a bit and perhaps be fine.
Old October 5, 2009, 06:47 PM
Silvgearx's Avatar
is your E6400 overclocked? if it is at 3.6ghz or so you won't notice much.
but if jumping from stock E6400 to I5 750 you will see a big difference.
Old October 6, 2009, 02:50 AM
Well it is stock right now and I have 333Mhz RAM (XMS2) so I guess I can get up to 2,6GhZ
Old October 6, 2009, 03:34 AM
Babrbarossa's Avatar
I would try overclocking the e6400- mine runs at 3.6GHz- buy yourself a heatsink with both 775 and 1366 adapters- then if you find you still want a boost, pick up the i5 and overclock that- you will see a difference, but there's quite a bit more you can get out of that e6400. (mine will reach 3.9)
Old October 6, 2009, 03:45 AM
sswilson's Avatar
Huge difference in the performance delta between your upgrade from E8600 to Q9550, and the upgrade he's looking at.
Your upgrade was essentially from dual core to quad within the same tech. He's going from low clockspeed first gen C2D tech with minimal cache, to the latest and greatest. In this case, I'm sure he'll see some fairly major noticable gains in performance.
Intel Core 2 Quad Q8200 vs Intel Core 2 Duo E8500 Hanibal{CA} New Builds 18 August 10, 2009 07:53 PM
FS - Intel Core 2 Duo E6600 Dual Core Processor LGA775 Conroe 2.40GHZ 1066FSB 4MB L2 pat767 Buy/Sell & Trade 0 January 22, 2008 10:00 AM
Comment thread for "Core 2 Duo e4300 vs. e6400: Performance on Air and Water Cooling Babrbarossa CPU's and Motherboards 12 August 7, 2007 08:12 AM
