<~----> Phenom II 550 - Hardware Canucks
Old October 3, 2009, 07:24 PM
jcmaz's Avatar
Default Phenom II 550
Hey HWC,
What are the chances of unlocking the third and fourth core of a Phenom II 550??
THX
-Plato
Old October 3, 2009, 07:36 PM
Cowboy's Avatar
When they first came out, if you had the right board, it was almost guaranteed. Now, with the new steppings and the new bioses out that disable the function, its next to impossible.
I would just get a quad if you need a quad, or a dualie if you need a dualie. They clock better.
Old October 3, 2009, 07:56 PM
jcmaz's Avatar
i was thinking about the 720BE and try to unlock w/ the 770T mobos from Gigabyte. But i'm not sure wat ram to use
-Plato
Phenom II X2 550 -X4 Vcore max mattlef CPU's and Motherboards 3 August 29, 2009 05:20 PM
Phenom II X2 550 BE the new "best bang for buck" CPU? GregH CPU's and Motherboards 11 August 8, 2009 04:10 PM
AMD prepares its Phenom FX, Phenom X4 and Phenom X2 lineups Babrbarossa Press Releases & Tech News 1 May 4, 2007 07:38 AM
