Old August 24, 2007, 12:51 AM
wpurcell's Avatar
Default Striker Extreme: Won't Boot!
Hello!
I just installed a Striker Extreme Mobo, and it will not boot. Here's my specs.: OCZ GameXStream 850 watt PSU/1GB Patriot PC2-6400/GeForce 7950GTOC/Antec 900 Case/Intel Core2Duo E6600. Anyone have this problem with the Striker?
I've tried a few things, including swapping out the vid card, memory, clearing the CMOS, etc. to no avail. All hardware was working in a previous life, in my P5NSLI.
So, anyone have any ideas what the problem could be?
Thanks in advance!:help:
Old August 24, 2007, 09:31 AM
3.0charlie's Avatar
Have you tried all 10 steps found here: http://www.hardwarecanucks.com/guide...ery-guide.html ?
But very quickly I would try to boot with a single RAM stick, and trying all 4 slots.
John
Old August 24, 2007, 02:31 PM
wpurcell's Avatar
No luck with the single RAM stick. I'll have a go at the "ten step" program. Thanks for the advice!
Old August 24, 2007, 07:28 PM
3.0charlie's Avatar
Keep us posted. Then again, it could simply be that the mobo is DOA.
Old August 25, 2007, 04:57 AM
does it even power up or anything? case fans cpu fans? can you get into BIOS? And what version BIOS? 1303 is the latest revision.
3800X2@2.2GHz--2gb PC3200--200Gb Maxtor SATA2--eVga 8800GTS 320mb--eVga nForce4 SLI mobo--Klipsch 4.1--Antec nine hundred case w/Vantec 120mm on side--Vista Premium 64bit
Join our Folding@Home team!
Old August 25, 2007, 05:44 AM
wpurcell's Avatar
Hello! Yes, it powers up, all the fans are working, the hard drives gear up, all the LCDs on the mobo light up. The reading on the LED is "CPU init", which if I am correct, means the CPU is intializing, but it hangs there, nothing else happens. "No Signal" is what my monitor tells me (we're on speaking terms!). NCIX has kindly sent me an RMA number, so I will likely ship it out on Tuesday next. I've not had any dealing with them in the past: is it likely they would send another board, or a refund? I guess I'll have to wait and see! That's quite the nice little Mobo.
Old August 25, 2007, 07:15 AM
3.0charlie's Avatar
You can choose to have either a refund or a replacement when you RMA. If you choose a replacement, they will only send the replacement item once they received the RMA board.
If you can't wait, you can also buy another (same) board and have it shipped right away. Once they receive the defective part, they will refund you.
As for troubleshooting, did you try to flash the BIOS? Do you have another RAM stick, with 1.8V default voltage? I don't know about the Patriot sticks, but default Ram voltage may not be enough.
Old August 26, 2007, 04:50 PM
Trial Member
Use a ps2 keyboard and mouse. go into bios and select default setup save reboot, power down, reconnect your old keyboard and mouse. Razor mice and some logitec keyboards have known to cause this CPU init problem on strikers. Hope this help for you.
Old August 26, 2007, 11:47 PM
wpurcell's Avatar
Hi Icedog! Couldn't get into BIOS: no signal to the monitor. It's on it's way back to NCIX! They'll see about a replacement or refund.
Old September 9, 2007, 08:00 AM
wpurcell's Avatar
Hello! The mobo is back, and I was wondering if there is a proper way to install it. As far as I know, bolt it in, attach the leads, and fire it up. Based on my last experience though, I'd like an opinion on the "best practice" method! I've got PC2-6400/800MHz 2x1GB memory, an OCZ GameXStream 850 watt PSU/ Intel Core 2 Duo CPU. Any ideas? Thanks in advance!
C2D E6600 on a Striker Extreme Freelancer Overclocking, Tweaking and Benchmarking 11 June 27, 2008 09:07 AM
Gauging Interest.. FS Striker Extreme / Intel C2D e6600 3Ghz r0k0 Buy/Sell & Trade 0 February 14, 2008 09:11 PM
AuzenTech Xplosion or HT Omega Striker BALISTX Audio 6 January 8, 2008 10:22 AM
Striker Extreme + 8500 Ballistix Tracer Don't play nice? CDE CPU's and Motherboards 3 August 23, 2007 05:24 PM
Striker Extreme/ compatible memory? wpurcell CPU's and Motherboards 2 August 23, 2007 01:41 AM
