<~----> E6850 Multiplier - Hardware Canucks
Old August 23, 2007, 07:14 PM
dukelod's Avatar
Default E6850 Multiplier
I put together a new system like last week and I used the new E6850 @3Ghz.
Now on intels site it said that the multiplier is 9, so looking at it with cpu-z and everest it jumps back and forth between 9x and 6x. Is this normal or has any one heard of it?, it's not overclocked and it don't seem to hurt the performance any. CS:S 1440 by 900 all setting maxed out in the video stress test the average fps is 285.16. (lg flatron ws 19")
Any insight would be great.
thanx in advance.
Intel Core i7 930
Thermalright Ultra 120 Extreme Black Ultra Kaze 3000rpm
EVGA X58 3Way SLI A1
Corsair XMs3 6GB DDR3 1600
Windows 7 Ultimate 64bit
Antec Truepower Quattro 1200 OC Version
XFX GTX295
XFX GTX295
Coolermaster HAF 932
Logitech G15 Keyboard
Logitech G5 Mouse
X-Fi XtemeGamer
Old August 23, 2007, 07:17 PM
magictorch's Avatar
Default cpuz
seems to be the software of choice...what does the bios say as it boots?
3oh6's Avatar
Hardware Canucks Reviewer
C1 or EIST or whatever its called. at idle the CPU drops the multi to run the processor at a lower frequency to save power. as soon as you put the system under load, it jumps back up. run orthos beta with CPU-Z open, you'll see.
Old August 28, 2007, 11:49 AM
dukelod's Avatar
Thanx magictorch and 3oh6, the bios is at 9x and it is doing what 3oh6 said it was.
Intel Core i7 930
XFX GTX295
XFX GTX295
Logitech G5 Mouse
X-Fi XtemeGamer
In Progress: AMD X2-5000 Black (unlocked multiplier) Lithotech Member Reviews 24 May 3, 2008 08:16 PM
SS phase change powered E6850 / Ballistix DDR3 3oh6 Overclocking, Tweaking and Benchmarking 9 November 9, 2007 10:46 AM
E6750/E6850 Unavailable? Dus CPU's and Motherboards 3 August 6, 2007 08:28 AM
e6850 at 500 fsb on Gigabyte GA-965P DS3 Babrbarossa Overclocking, Tweaking and Benchmarking 2 March 17, 2007 10:05 AM
