Old September 24, 2009, 05:28 PM
clone63's Avatar
If it supports atx, it supports matx. Some cases only support mATX. Some support mATX and itx. Make sure its both, some are just itx.
Old September 24, 2009, 06:02 PM
Polygon's Avatar
I have a mATX... things are always a little more cramped. For example my sATA ports would be blocked if I had a 10.5" video card. Also mATX boards tend to have fewer features.
Old September 25, 2009, 05:57 AM
Cowboy's Avatar
Any case that supports ATX will support mATX.
I have an acrylic one for sale, pm me and I'll cut you a deal.
Old September 28, 2009, 03:55 PM
If you have a large case (think Lian Li V2000), running sata cables can be annoying if they're on the "bottom" (which is inverted) of the board.
(The obvious) Less sata ports usually, don't usually find SLI/CF compatibility unless you're going for enthusiest boards.
And of course the obvious no triple/quad video card setups.
Old September 28, 2009, 04:23 PM
JD JD is offline
There are mATX boards with dual PCI-E x16 slots, so Crossfire/SLI isn't a definite no. You just won't have any other expansion slots if the cards are dual-slot design. If you go water though and get them to single-slot, then all is well.
For example: http://www.hardwarecanucks.com/forum...rd-review.html
Old October 7, 2009, 02:00 AM
If you are just ocing the cpu a bit and only have one video card, there's not much difference (performance and features) besides losing a few pci slots and sata ports etc
Possible for ATX board to fit in mATX case? dmelchart Cases 9 October 6, 2009 12:41 PM
mATX motherboard Phobia CPU's and Motherboards 0 February 12, 2009 06:16 PM
MATX Cases darksideleader Cases 10 August 10, 2008 12:42 PM
mATX overclocking -=CrAnSwIcK=- CPU's and Motherboards 2 August 8, 2008 09:23 AM
Which mATX mobo? BALISTX CPU's and Motherboards 2 July 25, 2008 09:21 AM
