Old September 21, 2009, 06:09 AM
Sandro_Bit's Avatar
Default EVGA P55 Mobo Sound Cutting out
Hey everyone, I wanted to know if you've come across a similar problem with your motherboard's onboard sound (all drivers updated including audio driver).
I just put together an i7-860 build (works flawlessly with Windows 7), the only problem i've encountered is that the sound will cut out after about 20-30 minutes of gaming. Windows sound cuts out too, I can only solve the problem by restarting the computer.
This problem has happened while playing Call of Duty 4, CS 1.6, and while watching YouTube videos.
I'm going to be calling EVGA tech support soon but if you've encountered similar problems with other mobo's and can lend some advice or support it would be great. thanks a lot!
Old September 21, 2009, 06:37 AM
Latest BIOS update?
Old September 21, 2009, 06:42 AM
Sandro_Bit's Avatar
yep i downloaded & installed it off the EVGA website.
Old September 21, 2009, 09:37 AM
Bojamijams's Avatar
which mobo specifically?
Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 16gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
Video: 2x R9 290 @ 1050 / 1375 | ASUS VG248QE |
Audio: STX => Audioengine A5 / audio technica AD700X
Old September 21, 2009, 11:08 AM
Are you 100% certain it isn't the actual connections from speakers to sound port? If the contact on the mobo isn't perfect it could be that as well.
Old September 21, 2009, 11:32 AM
Sandro_Bit's Avatar
so i spent my morning figuring out that it was in fact my wireless card that i plugged into the PCI slot. the card was what was causing the sound to cut out. i was able to hear everything while I played COD4 for 1 hour with the card removed. thank God for 14 day Best Buy returns.
Old September 21, 2009, 11:38 AM
sswilson's Avatar
It might have been a resource conflict with the card. Did you try resetting the PCI resources with all of your devices connected to the system?
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Monitor
Old September 21, 2009, 11:59 AM
LOL IRQ Conflict? Those happen still? hehehehehehe
Old September 21, 2009, 12:00 PM
sswilson's Avatar
Heh... there must be a reason why motherboards still come with the option..... ;)
Old September 21, 2009, 12:27 PM
Sandro_Bit's Avatar
Originally Posted by sswilson View Post
It might have been a resource conflict with the card. Did you try resetting the PCI resources will all of your devices connected to the system?
no i didn't, not sure how to. i also realized one of the antennas on my wireless card is breaking off at the base of the antenna.
returning it no matter what, how do i reset the PCI resources?
EVGA p55 boards officially released voklskier4452 Press Releases & Tech News 0 September 7, 2009 09:36 PM
EVGA P55 Mobo Lineup Revealed + P55 FTW Preview Comment Thread SKYMTL CPU's and Motherboards 11 August 22, 2009 10:31 PM
Worth it to buy a sound card or will MOBO sound be enough? Sandro_Bit CPU's and Motherboards 18 August 22, 2009 09:44 AM
