Old September 19, 2009, 09:27 AM
Cowboy's Avatar
Default Help me choose new motherboard (mATX)
Howdy all,
Just need to decide on which board to get for my current build.
Must have:
mATX form factor
ddr3 support
am3 socket compatible with x2 550BE
at least 1x pci-express 2.0 x16
at least 2x pci slots
Ok... go! Just kidding, any help is immensely appreciated.
Old September 19, 2009, 07:41 PM
clone63's Avatar
MSI's 785GM-E65. Has what you wanted, and the sata ports are cornered so that can't be covered by honkin GPU. Looks nice, has nice mosfet and nb heatsink. I think I read a review that you couldn't adjust the vcore but that doesn't seem right so maybe d/l the manual.
Otherwise I'd say ASRock's M3A785GMH. Not the features mentioned above but the sata's are high enough as not to be covered by a gpu. Cheaper too, but I think has 1 less fan header. Best of luck
Old September 19, 2009, 07:48 PM
Cowboy's Avatar
Thanks, I saw this one and I liked it too.
Old September 19, 2009, 07:49 PM
clone63's Avatar
MSI's?
Old September 19, 2009, 08:04 PM
Cowboy's Avatar
yeah the msi caught my eye.
Old September 19, 2009, 09:00 PM
clone63's Avatar
Seems like the best mATX solution for anyone wanting to install a gpu with AM3 and DDR3 options. That Vcore thing though, might want to check the manual or scan a review. If you go with it let me know, looks like my current boards replacement in the half distant future.
ASUS' might be alright, most pricy though and I'm just an Asus fan..or hater. Jetway has a cheaper but bad sata positions and 2 RAM slots. PFt.
Oh ya, I got your CPU in the mail, thanks! Gonna try and install it tomorrow.
Best Suggestion for an mATX motherboard Conky CPU's and Motherboards 4 March 5, 2009 10:21 AM
mATX motherboard Phobia CPU's and Motherboards 0 February 12, 2009 06:16 PM
Trying to choose a motherboard/chipset bmfmass CPU's and Motherboards 14 November 21, 2007 04:24 PM
