Old September 15, 2009, 08:11 PM
Chilly's Avatar
Originally Posted by grinder View Post
ahh good old white aluminum oxide thermal compound. cheaper, simpler application, and cleans up WAY better than the over priced/over rated stuff.
'cept the fact that most of us here on HWC got the stuff for free!
Old September 15, 2009, 09:09 PM
Extreme_kid's Avatar
LOL how did you get it for free ?!
Im going to try warming up the tube for few minutes with a heat gun on lowest temp and do the glob method and push the heatsink down on it without any twisting to avoid air pockets as much as possible , Ill post back in a few days for everyone who wants to know the result...
Has anyone ever tried mixing two different pastes and applying it to your cpu ?
Old September 16, 2009, 06:27 AM
bojangles's Avatar
No. And you should NEVER do that. Companies make them for a special purpose. You're talking about mixing chemicals that fuse together, which could do damaging effects to your HS or CPU. Do us a favour and just stick to one.
The only time I've ever seen someone mix two pastes were to stick ramsinks onto GPUs. I believe it was Ceramique and AS5 or something. It was for bonding purposes only.
Old September 16, 2009, 07:50 AM
ahhh I see , LOL I was never gonna do that , JUSTasked out of curiosity but thnx for the info ! how did you get free IC diamond 7 btw?
Old September 16, 2009, 08:05 AM
odis172's Avatar
He means we got the cheap white stuff for free. It does a decent job, and its so cheap, little tubes will often times come with random heatsinks you may purchase.
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old September 16, 2009, 08:47 AM
Andy's Avatar
I had the same issue with my free tube of IC7, as I too did not read enough ahead of time. As mentioned 10 minutes in a bowl of hot water makes it much easier to use. I used the pea sized, chocolate chip etc method and let the heat sink do the work of spreading and all has been fine.
SAGER 5165 - Matte Screen (1920x1080) - i7-2630QM - nVidia 555M - 8Gb DDR3 - 120Gb Corsair Force GT SSD - 500Gb Momentus XT - IntelŪ 6300
Old September 16, 2009, 02:26 PM
Silvgearx's Avatar
those IC 7 don't work as good as they do on TRUE 120. They are best used with direct touch types.
for both TRUE 120 i had, i prefer MX-2, easier to clean and install.
in both of my TRUE120 i only saw a 1-2C differences underload and 3 times the trouble of installing the TIM and removing it
Old September 19, 2009, 02:23 PM
thnx for the advice , Im gonna try that as soon as finish lapping the cpu.
why trouble with removing ?! btw mines a True Black.
  #19 (permalink)
Im looking for a NOT as hard kind of thermal paste for my north/south bridge , something that can be easily spreaded with card ? what do you recommend ?
  #20 (permalink)
Old September 19, 2009, 02:44 PM
Supergrover's Avatar
MX-2
Doesnt conduct and is a dream to use compaired to IC-7.
I use the pile of dogcrap method (pea sized blob) for IC-7 and it mount's well.
Makes a good polishing compound too.
R.I.P.
Thermal Paste miggs78 Water Cooling 4 September 10, 2009 07:17 PM
Thermal paste for a phenom II Jonwall CPU's and Motherboards 9 February 6, 2009 05:34 PM
your thermal paste method CTA CPU's and Motherboards 25 December 16, 2008 02:12 AM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 06:43 PM
Does core2duo come w/ thermal paste Magice CPU's and Motherboards 4 July 12, 2007 03:40 PM
