Old September 13, 2009, 03:24 PM
Question EVGA X58 vs P6T
EVGA X58 SLI LE Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Its versing the default P6T
Im ready to buy my board now i have brought my case nzxt lexa, and a 850 corsair psu.
I will be putting a i7 920 and a x285 on the board, its mainly for gaming what shall i go with i just do like the look of the EVGA, also i dont even know what sli meens so im
Old September 13, 2009, 04:04 PM
Killswitch's Avatar
Does your period (ie - ".") key work? Oh wait, nevermind. I see one in there.
Edit - I literally found this in less then two seconds by typing "sli" and hitting "enter" at GOOGLE.CA. Neat eh? It was the first link in the given list.
Scalable Link Interface - Wikipedia, the free encyclopedia
Old September 13, 2009, 04:16 PM
So i should go with evga
Old September 13, 2009, 04:42 PM
What do you plan on doing with your PC? Will you be overclocking? Will you be gaming? Will you use a multi-GPU setup? Will you use a PhysX card?
I would personally go with the P6T out of the two, but depending on what you'll be doing with your PC, there may be a reason for you to go with the EVGA board instead.
Old September 13, 2009, 04:43 PM
rjbarker's Avatar
For an additional (approx) $25 CDN go with the "proven" one...had this Board prior to my Classified Board..excellent Board!
EVGA X58 SLI Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
btw..evga = great support / products
Ultimately the decision is yours to make..
Classified SLi "Procyon II"
http://i30.photobucket.com/albums/c3...psafdd5ead.jpg
http://i30.photobucket.com/albums/c3...ps14a68ad9.jpg
3DMK 11
http://i30.photobucket.com/albums/c3...pse3993acf.jpg
Valley
http://i30.photobucket.com/albums/c3...psc01f1ceb.png
Old September 13, 2009, 05:25 PM
Im going to overclock my cpu and graphics card.
Old September 13, 2009, 05:30 PM
Answer the other questions please.
Old September 13, 2009, 05:59 PM
Im not a pc wizz i have no clew what that other stuff meens. "Will you use a multi-GPU setup? Will you use a PhysX card?"
My pc build specs - My New Gaming Build, Support.
Old September 13, 2009, 06:18 PM
In that case, I'd go with the P6T. But I have a bit of a preference toward ASUS boards in general; it really doesn't matter much which one you pick. The best option is probably just to get whichever is cheaper.
Old September 13, 2009, 07:22 PM
rjbarker's Avatar
If your planning on OC'ing your CPU the evga Board is a breeze for OC'ing newbs to learn on.....the X58 Support is awesome for any troubleshooting and general support...provided Asus has a similar Site then for sure either one.
I find I'm constantly accessing the Evga Forum for answers..
EVGA X58 SLI Series
Cheers
3DMK 11
Valley
P6T Vanilla vs Deluxe v2 vs Evga x58 OpTioN CPU's and Motherboards 3 May 22, 2009 09:01 PM
RAM Recommendation for i7 - ASUS P6T X58 Deluxe Rig Strato RAM 12 April 27, 2009 07:49 AM
Asus P6T or EVAG X58 mchutch CPU's and Motherboards 5 April 16, 2009 07:02 PM
EVGA X58 Vs Asus P6T X58 Deluxe appplejack CPU's and Motherboards 52 December 9, 2008 10:26 PM
Asus P6T X58 Deluxe Westmere 32nm compatible? ev0styLe CPU's and Motherboards 2 December 7, 2008 04:05 PM
