Old September 17, 2009, 10:13 AM
What swayed me away from EVGA is that their fan controllers don't work. So my vote is for the Asus.
Old September 17, 2009, 05:59 PM
If your gonna do heavy overclocking (at least 3.8ghz). I would recommend the EVGA board as, from my own experience it overclocks as well, or better then the other x58 boards in it`s price range (Got my i7 920 D0 to 4.35ghz) while looking a lot sexyer :D.
If you plan on doing regular overclocking(3.2-3.6) you could probably make do with a cheaper motherboard like the Gigabyte X58-UD3R and save yourself some money, I don`t know how many bells and whistles you need for your PC, but it sounds like a standard board like the ud3r will meet your needs at a much lower price point.
If your dead set on both these board and plan on mild overclocking - Pick the cheaper one.
Final Note : If you don`t know what SLI is that means you won`t miss out on it as the UD3R does not come with SLI support out of the box (it can be bios flashed to support it)
P6T Vanilla vs Deluxe v2 vs Evga x58 OpTioN CPU's and Motherboards 3 May 22, 2009 09:01 PM
RAM Recommendation for i7 - ASUS P6T X58 Deluxe Rig Strato RAM 12 April 27, 2009 07:49 AM
Asus P6T or EVAG X58 mchutch CPU's and Motherboards 5 April 16, 2009 07:02 PM
EVGA X58 Vs Asus P6T X58 Deluxe appplejack CPU's and Motherboards 52 December 9, 2008 11:26 PM
Asus P6T X58 Deluxe Westmere 32nm compatible? ev0styLe CPU's and Motherboards 2 December 7, 2008 05:05 PM
