Old August 19, 2007, 09:06 AM
Default Why temperature on core #1 and 3 different than core #0 and 2???
Is somebody know why the temp on Core #0 and #2 are about 5 degrees higher than Core #1 and #3? The difference is about 2 degrees with Prime95 (on all cores) for an hour compare at iddle!
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
Old August 19, 2007, 11:03 AM
Fallen Folder
i consider it normal.
reorienting the hsf 90 degrees may help.
also, could be a less than perfect contact between cpu ihs and hsf contact.
... lapping either/both may help or reseating or altering the amount of tim used.
Even with all the above i would still expect to see a variation, but maybe a bit smaller ... i haven't bothered to do any of the above with mine.
Old August 19, 2007, 11:46 AM
sswilson's Avatar
I don't believe intel quads are true quad cores yet.... Aren't they still dual core chips doubled up?
With that in mind, no two chips are going to react the same way under perfectly matched conditions, let alone separated and mated to the ihs at different points.
Lian-Li PC-011 Air (RGB) / Custom WC / Intel 730 Series 480GB SSD / Intel 760p 512GB NVMe / ASUS SWIFT PG279Q
Dell Optiplex 3020 / Intel Core i3 i3-4160 / EVGA GT 1030 SC / 6GB DDR3 / Samsung 850 EVO 500GB SSD/ Samsung 27" 1080p (Curved)
Dell G3 - i5 8300H / HP EX920 512GB NVME / 2X8GB HyperX Impact / 1TB SSHD / GTX 1050ti / N156HHE-GA1 120HZ Screen
Old August 19, 2007, 12:14 PM
I have almost the same thing :
From what i gathered from the net and ppls, it's normal. Whatever time you mount your heatsink\waterblock.
Old August 19, 2007, 01:01 PM
[quote=Patriote;17519]I have almost the same thing :
...in your case, it's core #0 and 1, then #2 with 3. Strange maybe, maybe not!
Old August 19, 2007, 04:39 PM
I personally feel that it is the different dies reacting to voltage differently since they are not true quads yet. It could also be variations in the thermal diode on each die. That and Intel doenst make the best IHS so it could be making different contact under the IHS.
Old August 20, 2007, 06:06 AM
Trial Member
usually its the Core 0 and 1 and cores 2 and 3 with nearly the same temps
Old August 20, 2007, 06:53 PM
Unklmo's Avatar
mine seems to be core # 3 by about 6-7 degrees.
curious
Old August 22, 2007, 10:42 AM
Everest give the same temp reading as CoreTemp...
Maybe the work is not distribute the same from one computer to another!
FS - Intel Core 2 Duo E6600 Dual Core Processor LGA775 Conroe 2.40GHZ 1066FSB 4MB L2 pat767 Buy/Sell & Trade 0 January 22, 2008 10:00 AM
V-Core Problems Dashock Troubleshooting 14 January 12, 2008 01:20 AM
Core temp's ? Unklmo CPU's and Motherboards 18 August 23, 2007 02:18 PM
Core Status = 63 (99)? 3.0charlie HardwareCanucks F@H Team 3 August 20, 2007 02:22 PM
