Old September 10, 2009, 11:15 AM
Default P55 v x58 Questions
I'll be looking to get a new board soon and both of these are very appealing. Obviously cost/performance is what is concerning me. My plan with this new rig is to grab 1 card for now (260/275) and whenever the 300 series comes out, upgrade to 2/3 way sli. With that being said, I've read numerous things about P55 running in 8x/8x/8x. I can't seem to find an answer, does the EVGA P55 run more than one 16x slot? Or do any other boards out there run 2-3 16x slots? I thought that was what the NF200 chip does, but I'm not 100% sure on it. Anyways, I still have a few weeks to decide but I love doing my shopping in advance.
Old September 10, 2009, 11:29 AM
the x8 will most likely bottleneck the new cards if your running more then 1. So I would recommend an x58 for that.
If you plan to just get 1 huge card like a 5870x2 the P55 is the way to go.
Old September 10, 2009, 03:23 PM
Sagath's Avatar
after reading the review on anandtech about the new gen of ATI cards, my guess is that x16 may even be limited, let alone x8
AnandTech: Beginnings of the Holodeck: AMD's DX11 GPU, Eyefinity and 6 Display Outputs
Old September 10, 2009, 04:03 PM
MpG's Avatar
MpG MpG is offline
If even the most optimistic of the rumours for the upcoming cards are true, there's no way PCI-E 2.0 x16 is going to be a bottleneck. I have yet to see conclusive evidence that current dual-GPU cards bottleneck with an x8 connection.
Regardless, if you honestly think you'll want Tri-SLI, that pretty much rules out the P55. SLI+PhysX will be okay, as long as the motherboard's got the room for it, but still not a very elegant one.
Old September 10, 2009, 04:37 PM
b1lk1's Avatar
P55 (lga 1156) and X58 (lga1366) have different sockets. P55 is for the new i7 8 series and the i5 series while the X58 is for the i7 9 series processors.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old September 10, 2009, 06:16 PM
belgolas's Avatar
There are no dual 16x P55 mother boards and none that support Tri SLI so far that I know of. Although the EVGA P55 classified is in the works but if you are spending that kind of money might as well just get a X58 board.
P55 will be fine with SLI but not Tri SLI.
Remember that PCIe 2.0 is double the bandwidth of PCIe 1.0 so that means that you have 32 PCIe lanes in 2.0 compared to 1.0. 8x PCIe 2.0 is like 16x PCIe 1.0 and I still don't think that PCIe 1.0 is fully saturated.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old September 10, 2009, 09:31 PM
Yeah I was curious about the Classified board. There's also the ftw 200, a bit cheaper and a bit more appealing.
Old September 11, 2009, 07:39 AM
Bojamijams's Avatar
ftw 200 will support triple SLI (x8/x8/x8) but don't count on it supporting the next gen too well.. I'm thinking its gonna exceed the x8 bus on the top end single gpu solution.. let alone dual gpu solution
if you're going to dump the kind of money it takes for triple SLI, don't cheap out on $25-$50 by going with a P55 mobo instead of an x58
Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 16gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
Video: 2x R9 290 @ 1050 / 1375 | ASUS VG248QE |
Audio: STX => Audioengine A5 / audio technica AD700X
Old September 11, 2009, 08:14 AM
Alright, I'd love to save money but :( Thanks for the help!
DFI Launches Single P55 Motherboard, DFI LANParty DK P55-T3eH9 FiXT Press Releases & Tech News 7 September 9, 2009 02:46 PM
EVGA P55 Mobo Lineup Revealed + P55 FTW Preview Comment Thread SKYMTL CPU's and Motherboards 11 August 22, 2009 10:31 PM
GIGABYTE P55 & Second-Gen X58 Motherboards Revealed MAC CPU's and Motherboards 13 June 29, 2009 11:15 AM
