Old August 18, 2007, 05:12 AM
Unklmo's Avatar
Default Core temp's ?
just curiuos as to why there is such a big difference in the temp's displayed between Speedfan and CoreTemp ? i'm seeing a 15 deg difference.
Old August 18, 2007, 05:42 AM
3oh6's Avatar
Hardware Canucks Reviewer
G0 stepping C2Ds have a 100C Tjunction, as shown in CoreTemp 0.95, your version of SpeedFan is still using the 85C Tjunction that previous stepping C2Ds use, hence 15C exactly lower. If you were to open up CoreTemp 0.94, you would see a Tjunction reported as 85C and the temps would be the same as SpeedFan.
CoreTemp 0.95 is correct, SpeedFan is wrong...perhaps an update to SpeedFan is available that will recognize the G0 as a 100C Tjunction and show correct temps. Or you could simply offset the temps manually by +15C and it will show them correctly. HTH
Old August 18, 2007, 12:13 PM
Patriote's Avatar
Thanks for the info. I have the same problem. Speedfan is 15c lower than coretemp 0.95. I have the latest Speedfan which is 432 i think.
BTW: Unklmo, you do know that you can get Orthos Beta which will stress Dual cores so you'll have to run only 2x Orthos ?
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
Old August 18, 2007, 04:16 PM
sswilson's Avatar
Doesn't the new Prime95 take care of all cores?
Old August 18, 2007, 04:58 PM
Patriote's Avatar
Not sure. I just downloaded the latest a few days ago and it does not.... AFAIK
- Asus P8Z68-V PRO
- Noctua NH-D14
Old August 18, 2007, 05:01 PM
sswilson's Avatar
Did it do at least 2 without needing to run different instances?
I had a link from here to a newer version that at least did that.
Old August 18, 2007, 05:04 PM
Patriote's Avatar
EDIT: Nope it does not. I have to set 4 instance to load 100%. 1 will load 25%. Maybe you gotta get the BETA version ?
- Asus P8Z68-V PRO
- Noctua NH-D14
Old August 18, 2007, 05:17 PM
sswilson's Avatar
Need version 25.3...........
http://www.hardwarecanucks.com/15266-post4.html
Enjoy!!!! :)
Old August 18, 2007, 06:17 PM
Patriote's Avatar
Enjoy!!!! :)
Only for Dual cores, right ?
- Asus P8Z68-V PRO
- Noctua NH-D14
Old August 18, 2007, 06:54 PM
b1lk1's Avatar
Speedfan is garbage in my experience. It hasn't worked right in a very long time.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
AMD Triple Core... Want or Don't Want? chibi_man CPU's and Motherboards 23 January 31, 2008 09:50 AM
FS - Intel Core 2 Duo E6600 Dual Core Processor LGA775 Conroe 2.40GHZ 1066FSB 4MB L2 pat767 Buy/Sell & Trade 0 January 22, 2008 10:00 AM
Why temperature on core #1 and 3 different than core #0 and 2??? francois methot CPU's and Motherboards 8 August 22, 2007 10:42 AM
Core Status = 63 (99)? 3.0charlie HardwareCanucks F@H Team 3 August 20, 2007 02:22 PM
