Old September 7, 2009, 01:34 PM
Bojamijams's Avatar
Default So P55 can't do a video card + physx+ audio?
Since the P55 chipset only has 20 pci-e lanes
GPU: X16
PhysX: X4
Sound Card = ....?
Am I getting that right? Seems.. odd.
Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 8gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
Video: 2x Sapphire 6950 Toxic 2gb @ 6970 @ 890 / 1350 | Dell U2711 |
Audio: STX => Audioengine A5 / beyer|dynamic DT-880 600ohm
Old September 7, 2009, 01:57 PM
MpG's Avatar
MpG MpG is offline
I believe the PCH can provide up to 8 PCI-E lanes, although they're only at first-gen speed, which is why Nvidia wouldn't certify them for actaul graphics usage, only PhysX. So as long as the mobo maker has provided the slots, you could give four lanes to a Physx card, and still a couple left over for sound, NIC, etc.
Old September 7, 2009, 02:05 PM
I believe that LGA1156 CPUs have 16 lanes, and the P55 PCH will have 8. However, the specific lane allocation will depend on the board, so you may end up having to run 8x/8x/1x for the video card, PhysX card, and sound card respectively, or you may be able to run 16x/4x/1x.
Old September 7, 2009, 02:35 PM
Bojamijams's Avatar
Oh I see so its actually 24 lanes not 20? Thanks :)
Old September 7, 2009, 02:47 PM
I thought it was 4, but according to Wikipedia the P55 PCH has 8 PCI-E 2.0 lanes. I'm actually not 100% sure on that number, so it could still turn out to be 4, in which case the configuration would be 8x/8x/1x.
Old September 7, 2009, 02:59 PM
MpG's Avatar
MpG MpG is offline
Disclaimer: As best I understand it. There's been a number of claims put out, but this seems to be the most reliable one. There seems to be a little term-fudging as well, as the lanes provided by the PCH are apparently "PCI-E 2.0 compatible", but they actually only run at first-gen speed. So you can plug a 2.0-spec device into them, but it's only going to get 1.1-spec bandwidth. Perhaps that's not an issue with PhysX, but it helps explain why Nvidia won't support Tri-SLI on triple-slot P55 motherboards, just SLI+PhysX.
Old September 7, 2009, 03:32 PM
Chilly's Avatar
Sigh... Alright, let me clear this up, the i5/i7 LGA1156 chip has x16 PCIe 2.0 lanes, now the P55 chip is connected to the CPU via a DMI link, which is the equvilent of a 4x PCIe 1.1 link.
So the "20" lane figure is CORRECT, as this is by how many lanes the CPU has access to. HOWEVER, the P55 chipset has by itself a certain amount of PCIe lanes it can give out, BUT this does not increase overall system bandwidth as it must be compressed down to fit the DMI link(4x PCIe 1.1) anyways. Until Intel releases the P55 chip, there is some conflicting information on how many PCIe lanes the PCH will actually have to give out, but I can guarantee that it will have *at least* 6x PCIe 1.1 lanes.
So just to clarify, the PCH(P55) could have 1,000,000,000,000x PCIe 2.0 to give out, but it doesn't change the fact that it still has to communicate all that via the sole DMI link which has the equivalent bandwidth of a 4x PCIe 1.1 link. Hence, the i5/i7 LGA1156 CPU's can be said to only have 20x PCIe lanes to communicate with.
Having said all that, don't worry too much, there's plenty reasons why one might want to go with X58 based system vs a P55 system, but you'll be able to plug more than just 1 graphics card and a physx card in a P55 system. There are solutions out there(such as PCIe lane splitters, ala the NF200 chip) that will allow folks to plug in everything they want into a P55 based system, bottleneck issues aside.
You'll be able to have your Dual GPU+PhysX+Audio on P55 and have it work just fine, the real question will be, will there be any bottlenecking+performance issues or not, and if so, how major/detrimental are they.
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
Bill Watkins, CEO Seagate Technology
Dual Xeon X5650 @ 4.1GHz | EVGA Classified SR-2
2x4GB G.Skill at 1496MHz (9-9-9-24) | XFX 4890 XXX 1GB at 1000/1000MHz
Intel SSD X25-M 80GB Gen2 | Western Digital 1TB Black | SilverStone Zeus 1200W
Sound Blaster X-Fi XtremeMusic | Sony MDR-V700 | Windows Seven x64
Stuff for Sale! You must buy it, you can't look away!
Old September 7, 2009, 05:54 PM
Bojamijams's Avatar
Well thats the thing and I guess until we get some numbers on the 5870 (and later the G300) we won't know if a single GPU can actually even use 8x speed.
But whats worrying me is this 1.1 lane speed. Does the PhysX need 2.0 or is 1.1 enough? For audio cards I assume 1.1 is plenty
It doesn't seem very future friendly this 1156 platform.
Old September 8, 2009, 12:13 AM
Chilly's Avatar
Originally Posted by Chilly View Post
<snip>Until Intel releases the P55 chip, there is some conflicting information on how many PCIe lanes the PCH will actually have to give out, but I can guarantee that it will have *at least* 6x PCIe 1.1 lanes.</snip>
Taken from HWC's review
I was correct, well, mostly, ended up that the PCH(P55) has 8x PCIe 1.0 links instead of only 6x. Everything else I have been saying about P55 and LGA1156 also turned out to be correct, such as the P55 being connected to the CPU via a DMI link with the equivlent bandwidth of a 4x PCIe 1.0 link. My advice/information stays relevant.
Not that P55, LGA1156, and the i5/i7 brand have been a well kept secret though!
Old September 8, 2009, 03:45 AM
This is exactly what I'm looking at right now, as I see an upgrade in my near future. i5 or i7, I sure like the cost difference though!
ASRock P55 Bundles SATA III Card with Motherboard FiXT Press Releases & Tech News 2 August 18, 2009 10:31 AM
Physx Card NightRain Video Cards 15 July 9, 2009 06:55 AM
PhysX card for folding hertz9753 Video Cards 8 May 12, 2009 07:35 PM
PhysX card question Varroa Video Cards 5 April 4, 2009 11:06 AM
