-   -   is a quad core phenom or phenom2 better then intel dual core? (http://www.hardwarecanucks.com/forum/cpus-motherboards/22714-quad-core-phenom-phenom2-better-then-intel-dual-core.html)
Shadowmeph September 3, 2009 08:28 PM
I am really new to the AMDs and i am not sure what works with which board . to me AMDs have so many board it confuses me.
and since most AMDs are cheaper ( at least I think that they are) I was wonder if a quad core phenom or phenom2 better then intel dual core? I ask this because I was thinking of moving up to a quad core CPU but looking at the prices of Intel quad cores that are around the 2.6.3 ghz rand ..they are really expensive. I could probably get a decent AMD quad CPU for the same price as a Intel dual core, this is why I asked the question. I do have a amd Athon 64x2 5600+ but that thing runs about the same as my old P4 3ghz cpu.
where can I find info on a good mix of Motherboard and cpu ( AMD) because I am thinking of going AMD if they are decent in price as well as performance
jcmaz September 3, 2009 08:33 PM
AMD 720BE is about the same as your E8400.
Btw, the original Phenoms were crap, Phenom II's are better :)
Kayen September 3, 2009 08:43 PM
Phenom II's are very good.
X2 550 i'd say is equal to an e8400, at much less of a price.
X4's 955 & 965 are pretty damn nice, with both being BE's as well.
Kilauea September 3, 2009 08:43 PM
I would think an Athlon X2 5600+ to be quite a bit better than a Pentium 4 3.0.
I can't tell you how my Phenom II X4 940 performs compared to a Q9400 or to a Q9550. But I am very satisfied by its performance.
As JC said, the original Phenoms weren't too good, but the Phenom II are quite competitive in terms of price/performance.
As for Mobo.
AM3 mobo will require DDR3 RAM and AM3 CPU
AM2+ mobo will work with Phenom II(even the AM3) and require DDR2 RAM
Zero82z September 3, 2009 09:01 PM
Original Phenoms were much slower than Core 2 CPUs. Phenom II CPUs are a bit slower clock for clock but are pretty close. I would personally choose a quad-core Phenom II over a dual-core Core 2 CPU if they were the same price, but depending on what you do with your PC, you might benefit more from the faster single and dual-threaded performance of the Core 2 CPU than you would from the extra two cores of the Phenom II.
Caldezar September 3, 2009 09:23 PM
It really depends on what you're doing I'd say. If you're doing a lot of heavy multitasking, then you'd be better off with a Phenom II. Or if you do a lot of graphic design or modeling/animation that has you running multiple programs and transferring between them, then again you'd benefit from the quad core setup. But for most single, focused applications, you'll probably see a very slight increase from an e8400 or better Core2.
kingnubian September 4, 2009 07:27 AM
Mulithreaded apps or multi core aware applications will benefit more from a quad over a dual all things being equal. For day to day computing honestly I don't think that there is a difference. Still the Quad may be a better "future looking" investment as more & more apps are being designed to take full advantage of any additional cores.
bumfloss September 7, 2009 05:09 PM
if I were you I would pick up an amd 940 be quad core and a gigabyte ud4p (ddr3 edition for future proofing.
that would be budget conscious and very effective IMHO:thumb:
snoosebum September 7, 2009 06:29 PM
I believe 940 only has a DDR2 controller. You must be reffering to the 945 955 or 965.
bumfloss September 7, 2009 07:05 PM
yeah srry my mistake I didn't know that. Now I do:biggrin:
