Hey Everyone :) I have been getting some new things here and there, and just recently I have purchased the Ballistix Tracer memory PC2-8500 and a beautiful Tagan Black Pearl case...after installation of the memory and only a very slight OC, they wouldn't last more than 5-6 hours before my machine would start to slow and lock up. I took off my panel and the Ballistix was super hot. So I bought some Dominator fans and that doubled the time it took for the memory to overheat. I set it back to stock settings and it didn't help much at all. So I put my patriot back in and they are fine even though they are DDR2-800 running at 1066 with 2.3 volts...they are warm to the touch but not HOT like the Ballistix. I have: Asus Striker Extreme 680i E6420 @ 3.4 - Zalman 9700 Corsair 620HX And well, everything else shouldn't effect the memory. Does anyone think I just got a bad batch, or is it a special Striker 680i thing? The memory looks hawt in my case, but the darn things are just too hot...even with the dominator fans blasting them... ![]() Thanks :) |
I think your problem resides with the overheating of the ram. I have a pair of crucial ballistix pc6400 ram and I overclocked it to DDR2-1125 at 5-5-5-15-29. I have to put 2.3 volts to make it stable. At 2.1 volts they were already very very hot and memtest gave me alot of errors. So I put 4 pieces of double sided mounting tape and mounted a 60mm fan right on top of the ram. Now not only are they cool and fast, rest of the motherboard also saw some temperature drop. So I would recommend some kind of fan blowing on your ram, then try to put 2.5v on them. I think tracers are rated at 2.5v aren't they?
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/cpus-motherboards/2250-striker-extreme-8500-ballistix-tracer-dont-play-nice.html | ||||
| Posted By | For | Type | Date | |
| Asus Striker Extreme - PROHARDVER! Hozzászólások | This thread | Refback | July 29, 2008 02:45 PM | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| C2D E6600 on a Striker Extreme | Freelancer | Overclocking, Tweaking and Benchmarking | 11 | June 27, 2008 10:07 AM |
| Striker Extreme: Won't Boot! | wpurcell | CPU's and Motherboards | 10 | September 9, 2007 09:18 AM |
| Striker Extreme/ compatible memory? | wpurcell | CPU's and Motherboards | 2 | August 23, 2007 02:41 AM |
| Ballistix Tracer 2x512mb $55 and $35 after MIR | JayDee | Hot Deals | 1 | June 27, 2007 09:08 PM |
| Cricial Ballistix Tracer DDR2 1066 review by TechGage | Babrbarossa | Reviews & Articles from the Web | 4 | April 27, 2007 07:58 PM |
