Old August 11, 2007, 11:14 PM
Default Overclocking friendly mobo on a budget - need help
Ive been searching for some budget friendly mobos that hopefully will have some good overclocking. So far i have three choices to make
Asus P5N-E SLI
Gigabyte GA-965G-DS3
Gigabyte GA-965P-DS3 (whats the difference between the 2 gigabytes?)
Can anyone give me some insight on theses mobos. Also im open to other recommendations as long as its within around the $160 range
Old August 11, 2007, 11:30 PM
Somed00d's Avatar
i would get a P35 board like asus p5kc its in your price range too
Q6600 G0 @ 3.2ghz (965 chipset holding me back)
DFI Infinity P965-S
Gigabyte Geforce 8500GT
Buffalo Firestix FSX800D2C-K2G 2X1GB PC2-6400 CL5
OCZ XTC Active Memory Cooler
Seagate Barracuda 250GB SATA2
MCE Wireless Keyboard / Remote
Logitech X-530 Speakers
Swiftech H20-220 Water kit
Swiftech MCW30 NB Cooling
OCZ PowerStream 600W
Old August 11, 2007, 11:47 PM
the asus P5K motherboard is around 150-160$ depending where you look, and pretty much no matter what the p35 chipset gives you more features and overclocking functions then you'll even need.
[SIGPIC][/SIGPIC]
OCToolbox Reviewer
www.octoolbox.com
Old August 12, 2007, 12:18 AM
JD JD is offline
Although I like my P5N-E SLI, I'd have to recommend the P5K too. The P5K-SE is quite cheap.
965G = onboard graphics = worse OCing.
I've heard good things about the Gigabyte GA-965P-DS3.
If you get a P5N-E SLI, you have to either stick a fan(s) on the northbridge heatsink or replace it. I have the Noctua NH-U6 with 60mm(thin) Panaflo fan.
Old August 12, 2007, 01:38 AM
sswilson's Avatar
Go with a P35 chipset if you can as it will give you support for the newer 1333 FSB CPUs.
Just read a review on the EVGA 650i board which I think said it had support for the newer chips as well, so it would be worth looking into (you can never have too many options).
eVGA 650i Ultra Motherboard Review
Old August 12, 2007, 08:02 AM
3.0charlie's Avatar
Gigabyte GA-P35-DS3L. Love it. And cheap: 94$. Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard - DirectCanada
Old August 12, 2007, 09:07 AM
Dus Dus is offline
I suggest:
Gigabyte GA-P35-DS3R
Gigabyte GA-P35-DS3R ATX LGA775 Conroe P35 DDR2 1PCI-E16 3PCI-E1 SATA RAID Sound GBLAN Motherboard - DirectCanada
Old August 12, 2007, 11:22 AM
CDE CDE is offline
That can support the 1333FSB chips. Also a super popular OC'ing board.
P5Ks are OK, but they are ugly compared to the pretty gigabyte boards
Both the P5K and that board will offer very good functionality and OC'ing.
Good luck - picking just the right mobo SUCKS because there are just so much to choose from!
Budget PC Build BALISTX CPU's and Motherboards 13 March 6, 2008 07:52 AM
Uhoh, RUN! It is a Mac! ..Well, kinda :P (Dialup friendly) MacJunky Case Mods, Worklog & Gallery 4 January 4, 2008 04:22 PM
Need some advice for a low budget PC ebdoradz CPU's and Motherboards 14 December 14, 2007 07:52 PM
My new budget-ish pc kcksteve CPU's and Motherboards 21 November 27, 2007 11:24 AM
Budget system Wiked CPU's and Motherboards 15 October 13, 2007 02:49 AM
