Old August 27, 2009, 12:19 PM
Shadowmeph's Avatar
Default Broke off a round thing ( compacitor?)
I bought an asus motherboard a week or two ago and because of Asuss's great design for the Asus p5Ql pro mother board I broke off a ( not sure what it is actually called ) a round compacitor, it is round and has two pins that come from the mother board into it. anyways the design of this board is terrible for any newer large video card I broke this thing off trying to reach the clip so I can pull my video card. the funny thing is that when I started my PC it started up normally so the board still works and I have know idea what the thing was for but I pushed it back onto the two pins coming out.
heres a pic or the MB diagram with my very messy printing and drawing of the placment of the release click and the compacator thing
my question is this is this going to mess up my board or anything else?
I am not going to buy another asus board again I had bought one yesterday for my HTPC and the design is the same I can just barely get my HD3450 vid card to fit
Old August 27, 2009, 12:37 PM
MpG's Avatar
MpG MpG is offline
It's a capacitor, and it's job is likely to stabilize/eliminate voltage ripple going somewhere - possibly even that video card. Personally, I wouldn't want to run anything expensive on that board at this point - those pins aren't supposed to separate from the cap - so you're probably not going to be getting proper electrical contact. Does the capacitor heat up when you run the computer?
Old August 27, 2009, 12:41 PM
Arinoth's Avatar
I am hoping he put the polarized capacitor back in the right way, if not that thing is eventually going to pop and potentially cause other damages to his board... Most capacitors in electronics (aka motherboards, graphics cards and power supplies) are what we called polarized. That means they have to go in a specific direction/way for them to work, if you put them in the wrong way you run the risk of blowing the capacitor and causing other potential damage to your board.
Shadowmeph, its called looking at the lay out of the board before purchasing it. EVERY motherboard company allows you to see each of their specific models on their websites.
Here I am: here I remain
Old August 27, 2009, 12:53 PM
gingerbee's Avatar
rma rma
Old August 27, 2009, 12:57 PM
omgwtf's Avatar
We learn from our mistakes ....
Memento mori
Old August 27, 2009, 01:22 PM
Shadowmeph's Avatar
ok that is what I am going to do
Old August 27, 2009, 02:17 PM
Shadowmeph's Avatar
wow I just got back from Mikes computer shop and they won't do an RMA the guy there accused me of intentionally breaking off the compassator now I am out over 100 buck. what a joke I am never ever going to deal with those losers again .
the only reason I went there in the first place was because I would save time and the price of shipping
Old August 27, 2009, 02:36 PM
"Quote This..."
There are a bazillion people out there with these boards and all manner of video cards in them, never heard of others doing this.. You just were not carefull enough.
Edit: I looked at a ton of pics of your motherboard online, yes is is close to the clip, but you can work the clip without contacting the cap, if you are carefull.
Old August 27, 2009, 02:46 PM
Perineum's Avatar
Just replace the capacitor....
Those motherboards are much harder to solder on than 10 years ago but if you have a good enough iron you can do it. I'll be getting a proper air gun for doing this kind of thing myself. Lots of people with older boards have cap problems.
Old August 27, 2009, 03:31 PM
Shadowmeph's Avatar
how do I figure out which way does it go on? also where do I find a compasitor I have a few old video card laying around hehe
We Broke #150 top spots barrier Mr. Gruntsworthy HardwareCanucks F@H Team 15 March 31, 2009 11:45 AM
Water line broke and then anouther line broke muse108dc Off Topic 3 March 28, 2009 07:34 AM
Broke Asrock X48? SugarJ CPU's and Motherboards 4 September 23, 2008 09:48 AM
One of my HDDs broke tom.mullie Storage 4 June 6, 2008 04:31 PM
Just broke 100 K this weekend! zlojack HardwareCanucks F@H Team 4 May 19, 2008 06:53 PM
