  #51 (permalink)
Old August 28, 2009, 02:06 PM
"Quote This..."
compactulator
discombobulator
refrecternator
[F7]
CAPACITOR! THATS IT!
Black belt in CAPS LOCK.
  #52 (permalink)
Old August 28, 2009, 02:42 PM
Shadowmeph's Avatar
Originally Posted by Squeetard View Post
compactulator
discombobulator
refrecternator
[F7]
no it is the FLUX CAPACITOR my answer to anything I don't know
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
  #53 (permalink)
Old August 28, 2009, 06:22 PM
Shadowmeph's Avatar
well I think that I am going to try and use my soldering iron and remove the to pins that are in the board the soldering iron I have is a cheap one but it has the very sharp point so it should be very easy to heat the pins enough to pull them out. Now if I could find a place that sells "capacitors" in Abbotsford then I will replace it but I haven't found a place so far :(. what would be a good search enmgine to use to search for that type of business?
Folder :
  #54 (permalink)
Old August 28, 2009, 06:34 PM
Safearus's Avatar
I would advise just sending it in as it is to be repaired. Rather than possibly causing more issues with this board.
Current Rig: "Έρεβος" -- English: "Erebus" ::
ASUS R.O.G. Crosshair III 790FX
AMD Phenom II X4 955 @ 3.6 Ghz (Feck...)
Coolermaster Hyper 212+
Thermaltake Armor
Corsair TX850W
Mushkin HP3 2x2GB DDR3
Samsung SATA DVD-RW
MSI GeForce GTX 275 Twin Frozr
  #55 (permalink)
Old August 28, 2009, 06:39 PM
Arinoth's Avatar
Shadowmeph, DO YOU EVEN KNOW which hole is what (positive/negative) so you DO NOT blow the POLARIZED cap. If you DO NOT have a clue what i am talking about DO NOT REPAIR IT YOURSELF.
  #56 (permalink)
Old August 28, 2009, 06:45 PM
Shadowmeph's Avatar
actually I do because the other capacitors of the same type are all situated in the same direction, they also have half colored top, red on one side and silver on the other also the writing on top of the capacitor all face the same way.
I contacted Asus and they told me to contact mikes computer so I am SOL.
Folder :
  #57 (permalink)
Old August 28, 2009, 07:23 PM
Safearus's Avatar
IMO you should have an electronics tech do the soldering for you. These motherboards have very small tracings and if you look at the solder jobs currently on them, it's all machined. It would take a ton of skill to apply new solder and not accidentally short-out other traces/components.
Thermaltake Armor
Corsair TX850W
Samsung SATA DVD-RW
  #58 (permalink)
Old August 28, 2009, 07:29 PM
Dwayne's Avatar
I second the motion on not doing it yourself. A multilayer board can be a very difficult thing to work on properly too. What is a Multilayer PCB?
As stated, you also need to know the polarity of the cap, and you could disbond layers on the board with that soldering iron if you apply too much heat. Unless you have proper training and equipment I would highly recommend against trying this yourself.
You really need this stuff - Pace Direct - Conductive Rework Systems to do the job right!
Dwayne's Rig - eVGA x58 SLI LE : i7 920 @ 3.4 GHz : Mushkin 18GB mixed Silverline and Blackline : Corsair HX850W PSU : Corsair H100 : Corsair Obsidian 650D : eVGA GeForce GTX 580 : Creative X-Fi Extreme Music
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : Sapphire HD 6670 : Nmedia HTPC 1000B : Kingston 60 GB SSD Boot
Netbook - Asus eee
Tablet - Asus eee Transformer
Wife's Rig - Toshiba Laptop!
  #59 (permalink)
Old August 28, 2009, 07:37 PM
"Quote This..."
I say GO FOR IT!
  #60 (permalink)
Old August 28, 2009, 08:36 PM
ToXic's Avatar
if you even put the iron near the board you could risk damaging components... and unless you can make micro globs and be 100% still you will fry the board. ask ASUS is they will repair it for a fee.
Some kind of pathetic Apple convert
17" Macbook Pro (early 2011 model)
2.2Ghz i7-2720QM | 8GB Corsair DDR3 1333Mhz | 750gb Toshiba HDD | ATI 6750M 1GB
We Broke #150 top spots barrier Mr. Gruntsworthy HardwareCanucks F@H Team 15 March 31, 2009 11:45 AM
Water line broke and then anouther line broke muse108dc Off Topic 3 March 28, 2009 07:34 AM
Broke Asrock X48? SugarJ CPU's and Motherboards 4 September 23, 2008 09:48 AM
One of my HDDs broke tom.mullie Storage 4 June 6, 2008 04:31 PM
Just broke 100 K this weekend! zlojack HardwareCanucks F@H Team 4 May 19, 2008 06:53 PM
