Originally Posted by Kylzer Yeah most ram needs 1.65
whats speeds you're uncore speed?
as said before we need a bios read out. |
Uncore would (
should) be either 3140 or 3297. His bus is 157, ram was 1570. Uncore is ram multiplier x2 or x2+1. Uncore multiplier is thus 20 or 21 times the bus speed.
As was mentioned 1.65-1.66 is normal for i7 DDR3. Your temps are very safe and you should be able to go higher. Problem with E-Leet is it wont lock things like your Uncore ratio, ram ratio, etc on the fly. This is why, as great as e-leet and other similar programs are, I still prefer clocking things in the bios manually.
Watch your vdroop. Looks like you have 1.1v under load. Depending on how good your chip is, that can be pritty low. Check your stock VID and what windows displays as your boards running vCore, and your load vCore.
You can probably get that chip higher too, if you're only hitting 55c under load. Without touching any voltages, try (in the bios) locking your ram at 2:8, bus to 190 and uncore to 16x or 17x (3040 or 3230mhz). You should hit 3.8 no problems.
