Old August 11, 2007, 03:35 AM
Default Intel E2160 @3.6Ghz, 1.6V using Coolermaster GeminII
Well, I have finally got some better cooling, not that the stock coller's to bad. Anyway, Got the @2160 up to 3.6 but can get it any higer due to FSB wall. Anything over 400 FSB and the pc wont boot.
Current settings
400 FSB x 9
Memory running @ 500, 4-4-4-12-2T
I have tried everything. Its running rock stable at 3.6 @1.6V and temps are great 33'C idle and 61'C load.
Just did a Futuremark 06, so can anyone with a high end C2D please compare and comment on the score please...
Old August 11, 2007, 08:14 AM
Wankerfx's Avatar
Nice overclock. 100% is something to be proud of, I think most E21x0 series CPUs run into FSB walls around 400. Mine does 8x400 with 1.43V, but can't go any higher, no matter what amount of voltage I put into it.
Old August 11, 2007, 08:15 AM
JD JD is offline
Well your CPU score is a bit lower than mine. I get 3227 on my E6600 @ 3.6GHz.
Futuremark - ORB - Project Comparison
E2160 +Zalman9700NT +EVGA780i +4GbG.Skill ddr2-1000 DerekOldschool CPU's and Motherboards 18 March 11, 2008 08:06 PM
Coolermaster CM 690 kcksteve Cases 29 January 1, 2008 10:53 AM
Tuniq Tower 120 or Coolermaster GeminII with 2 x 125CFM Fans..? keenan CPU's and Motherboards 4 August 8, 2007 07:58 PM
Cooler Master GeminII Review by X-Bit Labs Babrbarossa Reviews & Articles from the Web 0 April 5, 2007 09:31 AM
