Old January 15, 2007, 08:11 PM
Trial Member
Default Intel Motherboard
hi guys i have the intel motherboard D975XBX socket 775, and i was wondering if i can use it to overclock. I also have the E6400 duo core processor. any ideas on the mother or has anybody overclocked using that motherboard?
Old January 15, 2007, 08:27 PM
Personally Intel boards are a good board to just use and be hasslefree. A decent or it seems board for overclocking is the Asus p5b
Old January 16, 2007, 03:11 PM
By far the best are the p5b deluxe and the gigabyte p965 ds3.
The xbx or "badaxe" is a pretty decent overclocker too though :)
The e6600 and above (conroes) overclock well on it. E6400 and 6300 (allendales)....not so well.
Go into the bios, and start oc'ing, it should still give you a nice 400 mhz fsb minimum, which would be easily enough for 2.8ghz on your e6400.
Old January 17, 2007, 09:24 PM
Misoprostol
Guest
Posts: n/a
The Bad Axe (D975XBX) is definitely a decent overclocking board. Go for it. The only problem is that you need to reset CMOS every time you push it too far :(
Motherboard and CPU help please vintank CPU's and Motherboards 0 January 8, 2008 08:13 PM
ASRock 4Core 1333-eSATA2 R5.0 Intel P31 Motherboard Review @ Madshrimps SKYMTL Reviews & Articles from the Web 0 September 11, 2007 02:00 PM
HEXUS on the new Asus Commando Intel P965 Express motherboard Supergrover Reviews & Articles from the Web 0 January 10, 2007 06:04 PM
